The headlamp washers have just stopped working on my GTI, i've checked the fuse and thats ok, can anyone give me any ideas on what else to check
cheers
Headlamp washers
Re: Headlamp washers
Mine tend to stop working when the fluid level is low??
Failing that, check the pipes on the rear of the jets, or the connections.
- Trottagti
Yeah mine have packed up aswell as my horn, any advice would help!
feel a bit stupid now! put some water in and they work, thanks Rossco!
Obviously theres a sensor in the fluid resevoir so only the windscreen washers work when the water is low.
thanks again
thanks again
Headlight washer pump has probably diedTrottagti wrote:Yeah mine have packed up aswell as my horn, any advice would help!
EDIT: Just found out some info. The fuse for the Horns is also for the Headlight Washers!! Yellow 20amp
- Tim_GTi
- Post Whore
If you've got less than 1litre in your fluid reservoir, the washers won't work.
