Passenger elec window just stopped working
htid
Post by htid »
Now i've read the posts about peoples windows not working. Now the case with my passenger side elec window is that it just suddenly stopped one day. It is in the up position which is fine but when you press the elec button it won't go down and no noise can be heard. I thought this might mean that a fuse had blown so I checked the manual for where to find the fuse box and it doesn't have the electric windows listed on there as a number? Therefore I'm not sure i'm looking in the right place (fuse box) or if indeed there is a fuse? Can anyone point me in the right direction, the drivers side window works perfect. Thanks
htid
Post by htid »
Still can't find a fuse for this? looked in fuse box as well as owners manual and its not listed as to where they might be. ANyone know if there indeed are any and if so where it is?
Zeus!
Post by Zeus! »
Open the door, take the cover off the wiring in the door pillar, theres usually a few snapped wires in there. If the fuse was blown the drivers side wouldnt work either.
charliec125
Re: Passenger elec window just stopped working
Post by charliec125 »
most common problem is the switches are blown,try get new ones of those first, thats wat my problem was.
randomage
Post by randomage »
ive ended up in the interesting situation in which the motor for my passenger window is no longer connected to the wires in some way. so, basically, unless i put something under the window (bit of wood did the trick nicely) it started creeping down. fun times... check the motor hasn't seized, as this happened to me a couple of times. also check the window is properly fixed to the runner - incorrect alignment of the glass will overpower the motor and it won't move (again, intermittent problem with mine)
charliec125
I was looking to buy a new motor thinking that was the problem, changed the switch and the window was trying to move, found out i have a block of wood under mine and wen i moved this the window fell into my door, this sucks, i need a new regulator now. Does anyone know if it's a tough job to do?
PeaGreen
Post by PeaGreen »
I still haven't got around to sorting my jammed windows. However, I understand that it's fairly easy but quite expensive to fix if you need to replace the regulator. I was quoted £180 (plu VAT) per side at my local VW dealer for replacements for my 2001 Variant a couple of weeks ago.
This was for the regulator and motor combined... the motor was available alone for about £150!
charliec125
I called VW and it's £74 for the regulator alone, thank god i didnt need the motor as it was sooo expensive. And we have a local vw specialist who will fit it for £40( a hours work) cos it looks really tricky,and you could ruin your door if you don't take it off right,and i dont wana risk that. Would you happen to know if it's easy to change a central locking pump..
PeaGreen
Post by PeaGreen »
charliec125 wrote:I called VW and it's £74 for the regulator alone..
Although I've now repaired mine without any parts, I'm intrigued about the massive difference in prices we were quoted from VW dealers. I was told I couldn't get the regulator on its own and that it would cost £180 plus VAT for each side.
Has anyone else had similar problems.
charliec125
well before the 6n2 the motor and mechanism could only be bought as a whole as far as i know.
