Wind screen wash problem
andreas.theoharous
Post by andreas.theoharous »
everytime i fill my windscreen wash more den half way it poors out frm the bottom which is really wired does anyone know whats happen hear.
alexperkins
Site Admin
Re: Wind screen wash problem
Post by alexperkins »
Thats most likely the expansion tank gasket broken through. The washer bottle on the GTI is in two parts. The top half for filling and washing the windscreen, and the bottom half for the headlight washers which is hidden behind the wheel arch liner and fills the arch up. There is a rubber seal that is between the two, and this can, over time, perish.
yosin
Post by yosin »
andreas.theoharous wrote:everytime i fill my windscreen wash more den half way it poors out frm the bottom which is really wired does anyone know whats happen hear.
i have the exact same problem, been meaning to ask about this..
alexperkins wrote:Thats most likely the expansion tank gasket broken through. The washer bottle on the GTI is in two parts. The top half for filling and washing the windscreen, and the bottom half for the headlight washers which is hidden behind the wheel arch liner and fills the arch up. There is a rubber seal that is between the two, and this can, over time, perish.
alex, so the problem is the rubber seal? if not what is not needed to fix this? surely this aint a MOT failure is it..?
alexperkins
Site Admin
31 is the bottle you see on top, 32 is the seal that needs replacing if its always leaking out constantly, though the arm off 31 that goes into 30 often snaps, and needs repairing with something like araldite.
alexperkins
Site Admin
Or its seal No 4 in this picture where the washer pump for the screen(s) connects into
cjwardy
Post by cjwardy »
I'm having this problem too.
The water is leaking out from the offside fog light grille.
Gonna get and check the rubber join this weekend as mentioned above
alexperkins
Site Admin
You may have a leaking headlight washer. Its a common fault where the pressure seal leaks and water trickles out the base of the washer.
