Cruise Control aftermarket kits
woter324
Post by woter324 »
Does anyone know if cruise control is fitted post-factory? or if there are any DIY cruise control kits available for fitting to the Polo 9N.
Was thinking of making one but it would be rather crude. Do the OEM ones work from the ECU?
Many thanks
woter324
Answered. Retro-fit?
Post by woter324 »
How do I retro fit the cruise control. I mean is it a simple task. Plug n' Play sort of thing.
Anyone done it?
des_pd_ tdi
Post by des_pd_ tdi »
Amd in Bicester retrofit cruise control, it's approx £275.
This is a lot of money but personally I'd pay for it from a safety aspect and their quality of work is second to none.
www.auto-amd.com
Nelson_Wilbury
Moderator
Post by Nelson_Wilbury »
It's possible to fit the OEM cruise control. But the only person on the forum who has actually done it (Sparkstack) is hard to get hold of! :cry:
So no ones quite sure how difficult a job it is, it is possible though.
woter324
Related DIY cruise contol How To
Post by woter324 »
Not quite Polo but VW and audi. Maybe they know about Polos. Anyway URL:
http://world.std.com/~bor/text/cruzefaq.txt
Thanks for help on oringinal post.
Scorpio1
Post by Scorpio1 »
If you already have the wiring, I.E on DBW (Drive By Wire) cars, it SHOULD be simple. New indicator stalk and VAG-COM to turn it on. However if you don't have the wiring, it will be tough but possible.
carmadaaron
Post by carmadaaron »
should have ordered it as a factory fitted option, its much easier! :lol:
woter324
Factory Fitted Option + DBW?
Post by woter324 »
Are but then there would be no challenge! Besides the fact it wasn't brand new.
Scorpio1:
Drive by Wire? never heard this term before. Sounds worrying. How do I know if my car is drive by wire. Any clues or tail tail signs. Any reference to VIN etc?
Many thanks
Scorpio1
Post by Scorpio1 »
The easiest way (probably not the safest) is to touch the brake pedal at the same time as the accelerator...
If it is DBW the revs will drop to idle straight away. I think all TDIs are not too sure about petrol.
woter324
DBW
Post by woter324 »
Any other way. Mine is petrol. Brake + Accl doesn't work.
Nelson_Wilbury
Moderator
I will be getting Cruise Control fitted hopefully sometime next month 8)
I'm hoping I won't have to bother with the Wiring, either way it'll stay under the £100 barrier :D
rooboy
Post by rooboy »
Nelson_Wilbury wrote:It's possible to fit the OEM cruise control. But the only person on the forum who has actually done it (Sparkstack) is hard to get hold of! :cry:
Apparently it is fairly easy and straightforward apart from threading the wires throught the polo platforms bulkhead, due to the less space than on the Golf platform.
A Skoda technician that I know is doing mine for me after I come back from my holiday in July.
