Hi All,
Although no one has replied to my last post (seat bolster) I wont hold it against you....but I do feel alittle sad inside....
Can anyone recommend a good cheap VAG Com for my 2003 1.4 Polo?
G
VAG Com
david burton
Re: VAG Com
I've heard that the only decent one is the proper one from Rosstech. Too many fakes out there that don't quite do everything. Can't help much more than that, sorry.
Re: VAG Com
Isn't VAG-COM just the computer programme? So I don't understand your question... lol
- pip_polo
Re: VAG Com
where you located? i'm sure someone with vagcom could help you out.
i have it and i know a few others dotted around have it that would do what ever for free
princess_trojan
Re: VAG Com
Sorry I was refering to a plug in fault reader...I have seen one in PW...Gendan Fault Reader and wonder if thats any use?
Re: VAG Com
Enough internet hersay..
I've got a Gendan hand held one, works on my 9N mates Lupos, 6N's what ever we've had it on so far! Works as it should and only £39.99..
google gendan...
Sepi
google gendan...
Sepi
princess_trojan
Re: VAG Com
Cheers Sepi, just what I wanted to hear! Order placed 5 mins ago!sep_rider wrote:Enough internet hersay..
google gendan...
Sepi
Re: VAG Com
I've got the Gendan VAG tool as well, remember it only covers ENGINE, SRS, ABS and AUTO TRANS - but it is good to have in the car - I tend to use VAG COM or VCDS as its now called for making changes or working on the cars at home. By the way, your next task will probably be to trawl the internet for a full fault code listing for VAG cars - the first four or five codes that I picked up on the Gendan scan tool were not on the list that came with the tool - but finding a proper VAG fault code list is not that harm - and it is worth doing ASAP - ie before you need it!
Re: VAG Com
Brake wear light is driving me nuts. I've have new front wishbone bushes, new disks and pads and new wiring harness from pads to ecu and the light will still intermittingly come on. Is there anyone in N Wales near Colwyn Bay who can switch the indicator off.
