I have slammed my 9n polo today
Changed the droplinks from standard ones to Ford Mondeo 2003 ones however now when i drive and brake the right hand side of the anti roll bar is scraping on the driveshaft
By changing the droplinks from standard to mondeo 2003 ones it is meant to solve this?
There is 1 and 1/2cm left of thread with the helpers out
What would be reccomended? change the droplinks? change the arb?
Answers ASAP please
Slammed My 9n Now I Have Problems
Re: Slammed My 9n Now I Have Problems
shorter droplinks trey the vmaxx ones they are tiny
Theres a droplink guide in the 9n3 section which is where it says use 2003 mondeo ones and there fine
thinking about it now the mondeo ones are only around 1inch shorter then the polo ones, is this why i have the rubbing?
aza_028 wrote:Theres a droplink guide in the 9n3 section which is where it says use 2003 mondeo ones and there fine
What coilovers have you got?
As you only have 15mm left on the thread I suspect that your just too low for even the mondeo droplinks
FK Highsports mate
So your roughly 85mm lower, all it will be is the mondeo droplinks are to long
Try these
http://www.dpmperformance.co.uk/vmaxx-s ... -2513.html
Try these
Will have to get these once get some cash, mondeo ones set me back £20 and thats down the drain now lol, cheers 4 that mate.
