ABS Light + Handbrake Light Flashing
Re: ABS Light + Handbrake Light Flashing
Yup checked the internal fuses.
I watched him do the work, he basically rewired the aftermarket harness and never messed with the actual wiring!!
Hmm it could just be coincidental. where abouts are you located mate?
I'm in stockport, The VAG cable arrived yesterday, i'll see what it says and let you guys know. Thanks
This is what the diagnostic said:VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 A
Component: 1.6l/4V SIMOS3 00HS3259
Coding: 00031
Shop #: WSC 00788
5 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17526 - Shareware Version. To Decode all DTCs
P1118 - 35-00 - Please Register/Activate
16524 - Shareware Version. To Decode all DTCs
P0140 - 35-10 - Please Register/Activate - Intermittent
17927 - Camshaft Adjustment: Bank 1: Malfunction
P1519 - 35-10 - - - Intermittent
16384 - Shareware Version. To Decode all DTCs
P1519 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0010 1001
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
It says no fault on the ABS, now I'm really confused!!!
Address 01: Engine
Coding: 00031
Shop #: WSC 00788
5 Faults Found:
Coding: 15603
Shop #: WSC 00788
clear the fault codes and rescan
then we can look at problems that are persitant
Ok I now get this:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 6N0 920 904 K
Component and/or Version: KOMBIINSTRUMENT BOO V05
Software Coding: 00444
Work Shop Code: WSC 00735
1 Fault Found:
01316 - ABS Control Module
49-00 - No Communications
So any ideas on how to fix it, checked all the fuses, what else could it be, maybe the HU issue I mentioned before, can't be a coincidence or can it?
1 Fault Found:
Any ideas?
The ABS module isnt getting any power. Try scanning the engine controller seperately, then the ABS controller seperately. Doing a full scan somtimes obscures the outcome.
i also have this problem help?...how to fix it done the above but doesnt seem to work i havent put it on a vagcom or that to check actually what the fault is though
Vaccine is always first port of call mate. Could be faulty sensor or I k ow with the ABS the fuses on the battery are very common to fracture
- Trottagti
Mine was doing this and it turned out to be my brake light switch on the pedal box..
May be another area to check, seems odd though....
I've come across a few with that fault, first time I tried a few things, ended up pulling the ABS ECU off the bottom of the pump and replacing it.
Solved the problem.
Solved the problem.
