Can anyone confirm the XZN bit I need for the suspension strut clamp on my 9N? I think it's an M14 but I've bought all the way up to M16 and have even heard rumours of an M18!
It's the same as a 12-point tool.
Thanks. I have a snapped spring on my KWs!
Suspension clamp XZN size or 12 point size?
david burton
Re: Suspension clamp XZN size or 12 point size?
I'm certain that it is an M14 as it seems that most of the standard kits only go up to M12 as I discovered when I needed to get this bolt out (broken spring). Its is XZX and probaby 12 splines.
Its best to have a tool for spreading the hub clamping bit as well - maybe from Laser Tools via Halfords (not stocked though - so they order it in!).
david burton
cheers
did this today - M14 indeed. pain in the backside to put the standard spring back in even with compressors. The KWs snapped yesterday, urgh.
Ah well, back to one standard spring, ordered a replacement from KW and will sort this out next weekend I hope!
david burton
K.I.T.T.
- Platinum Member
- Drives: Bicycle
^^I'm presuming that's not good.
Ash
Ash
david burton
Nope. Destroyed the top mount too, bearings everywhere. Thankfully the damper and piston of the KWs look fine.
Actually its usually only the top bearing that falls apart, spring laying in a short heap - yes I've still got one of them in the garage from the original VW spring doing that. Compressing the original tapered spring - yes a bit of a challenge, it helps if you have a few sets of compressors!david burton wrote:Nope. Destroyed the top mount too, bearings everywhere.
