It was a long while back I attempted it - I can't remember what worked and what didnt.. I have to recover my old threadf6had wrote:Hmm then what's the problem mate? Which kit are you using? Mine worked first time and works a charm every time.
Does your window up/down work with the key in the door barrel?
Remote central locking. How easy to fit?
Re: Remote central locking. How easy to fit?
f6had
Well if your window up/down works with the key in the door barrel (both n/s and o/s front doors) then the system is working. All the relay is doing is sending a signal to the unit to tell it to roll the windows up. You can't really get the wiring wrong if you've bought the right relay... it's crystal clear mate.
Recovered my old postf6had wrote:Well if your window up/down works with the key in the door barrel (both n/s and o/s front doors) then the system is working. All the relay is doing is sending a signal to the unit to tell it to roll the windows up. You can't really get the wiring wrong if you've bought the right relay... it's crystal clear mate.
jacko7165 wrote:if you have total closure off the key then you will need to purchase a 4 pin relay to hook that up
when you have a relay connect it as follows
pins 86 & 87 of the relay connect to 12v+(this can be taken from the red/white at the pump
connect the green wire from your r click kit to pin 85 of the relay
connect pin 30 of the relay to the grey/red lock wire at the pump
lowfoon wrote:OK, have connected all pins but I have several issues
Instead of grey/red I have white/yellow but I have determined it is the lock wire.
The car opens fine but when it locks I get 6 'bong' sounds from the front of the car and several dashboard lights on but faded. Also the windows do not roll-up
When I remove pin 85 which is connected to the green wire of the Rclick unit, the central locking works as normal but still does not roll-up windows
Any help appreciated!
f6had
So putting the window roll up issue aside, are you saying that you can't lock the car from the remote?
6 bongs? what are they?..
Yup when it is all connected the car doesn't lockf6had wrote:So putting the window roll up issue aside, are you saying that you can't lock the car from the remote?
Bongs coming from the dashboard area - Haven't a clue
f6had
When you connected the two yellow wires on the remote control unit itself, which red wire did you connect them to? I had a similar problem as I misinterpreted the instructions. You need to connect them both to the positive red wire to give it a 12v supply.
Hmm I have to dig out my relay and check it again.. Thanksf6had wrote:When you connected the two yellow wires on the remote control unit itself, which red wire did you connect them to? I had a similar problem as I misinterpreted the instructions. You need to connect them both to the positive red wire to give it a 12v supply.
f6had
No forget the relay, you need to get the actual RCL kit working before you bother with the window rollup function.
Are you anywhere near Bradford, West Yorkshire? If so, I don't mind helping you out.
On a sidenote, I've just left my Polo key with a local key cutting place to have the blades cut and they've supplied and programmed a Philips TPH1 transponder. All being well, I'll have a pair of working flip keys later today
I have a RCL kitf6had wrote:No forget the relay, you need to get the actual RCL kit working before you bother with the window rollup function.
I'm in London unfortunately
f6had
I'm not sure I even understand now. I thought the car doesn't lock with your RCL kit? If it doesn't then why even bother trying to get the window rollup to work lol
Anyways, I've been busy finishing off the install on my wife's Polo. Got both blades cut from a local place, and a new transponder supplied and programmed. For the second key, I cut out the old transponder from our single existing key.
I now have 2 working flip keys, and a spare master blade that can at least unlock the doors.
I'm quite impressed with the quality, they're not quite OEM but not bad for a universal key..
My RCL kit works fine.. When I put the relay in, then it doesn't lock and does the 'bong' businessf6had wrote:I'm not sure I even understand now. I thought the car doesn't lock with your RCL kit? If it doesn't then why even bother trying to get the window rollup to work lol
fitted mine today was pretty easy just follow alex tutorial.
does anyone know of someone/company in birmingham who will cut me 2 keys onto the blanks and put 2 transponders into the 2 remotes?
also the vw badge on the key, how do you get the rightclick one out?
I got all the stuff out the box and took the cl pump out of boot but don't have the balls to do it myself having never done anything electrical before. My mates dad is a sparky so hopefully if i ask nicely he'll do it for me. I didn't realise the key wouldn't work automatically, and like f9hard i also only have one key when I brought my polo so will need to get my keys cut and find two transponders. I live in the London area if anyone can help?rapid_f1 wrote:fitted mine today was pretty easy just follow alex tutorial.
Installed my Rclick on Sunday, am so chuffed with the result! Everytime I approach my car now I feel happier knowing it was me who installed it... well I had a little help from my mates dad!f6had wrote:No forget the relay, you need to get the actual RCL kit working before you bother with the window rollup function.
Next step in getting the keys cut and getting a transponder/immobilizer chip installed. Does anyone know a nationwide company that will do it? Or someone in London area?
Im having this problem dude,im from south London nobody seems to be able to laser cut keys, and a place i did find want £48 just for cutting one key., i heard VW or Audi cut them, but they told me they can only order new keysduke750 wrote:Installed my Rclick on Sunday, am so chuffed with the result! Everytime I approach my car now I feel happier knowing it was me who installed it... well I had a little help from my mates dad!f6had wrote:No forget the relay, you need to get the actual RCL kit working before you bother with the window rollup function.
On a sidenote, I've just left my Polo key with a local key cutting place to have the blades cut and they've supplied and programmed a Philips TPH1 transponder. All being well, I'll have a pair of working flip keys later today![]()
