Those caliper bolts look mighty tight and I would need solid support for the car..! Is it recommended to lift both sides of the car, i.e. two axle stands or just work your way around (guessing leaving three wheels touching will be more secure) - this looks a bit wobbly? http://uk-polos.net/viewtopi ... 10&t=42649
I have a trolley jack and normally raise on the rubber 'grommits' seen under the car... just unsure where exactly to place the axle stands... could be making myself look silly, but better safe than sorry!
![Smile :)](./images/smilies/icon_smile.gif)
![Image](http://i50.tinypic.com/18c2ly.jpg)
arrow shows trolley jack point rubber grommit and other arrow is where I think axle stand would go - lower suspension arm ??
![Image](http://i46.tinypic.com/2dhacn5.jpg)
guess this is the rear axle right? perfect for the axle stand ??
![Image](http://i45.tinypic.com/2nut0kn.jpg)
arrow shows trolley jack point, rubber missing
![Image](http://i49.tinypic.com/16bennn.jpg)
the sill type - no markings
![Image](http://i47.tinypic.com/jtb40g.jpg)
is this little rubber thing, designed to let any water out, that might get in the sill, there are four around the car - or is this points for the VW scissor jack crap?
Thanks in advance, itching to get these new discs and brake pads fitted...
Any other suggestions welcome on that front too - gone for OEM all round.
