I've got the calipers, with pads, pads retaining springs and the pad retaining pins. Also got the 4 bolts. When i got them I got all the corrosion off the pins and springs and sprayed the springs black quickly for some protection in future and the pins are now like mirrors. The pads have about 90% of the meat left and I also bought some goodridge tt lines and two banjo bolts (need shortening a tad) to attach them to the caliper.
All that is needed is the brackets to fit them on with the 312mm tt conversion people commonly use, these are available off eBay etc etc the lugs to hold the pads in place also need 2-3mm taken off to fit the 25mm discs in as the rear discs on the boxster are only 20mm
I am after 350ono can be contacted via pm or email:
[email protected], based in North Yorkshire
