central convenience fuse?
mikegti
Post by mikegti »
when you take the key out the ignition it should do two things:
the courtesy light should come on and also the radio should turn off ?
mine doesnt do this anymore :(
someone on ukmkiv's told me it was the central convenience fuse but I can't work out which one it is... anyone able to help?
cheers,
mike
Josh_PoloGTi
Site Admin
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
This happened to me too...
But the dealer fixed it up (it took them MONTHS to sort it out).
I have the wiring diagrams somewhere (the technical specialist that finally fixed it gave them to me!!)... I'll have a look for them over the weekend and will let you know.
By the way, mine needed a new ignition-switch bottom (the switch bit) as well as a fuse.
mikegti
Post by mikegti »
cheers Josh, thosewould be a real help! was the switch expensive?
oh and while you're here ... have you got any uk-polos stickers left, inside ones ?
cheers,
mike
inder
Post by inder »
sorry to bump this old post, Josh_PoloGTi do you still have the diagram?
