Dear All,
Please help, I am close to selling my motor...
In the last 4 months I have: -
Replaced all 4 coils
Replaced anti-roll bar bushes
Replaced drop links
And now I am rewarded with a new noise from the front drivers side suspension area...its not a knocking noise more of a dry ooh ooh noise. Not affected by speed so happens at 20mph and 70mph but not all the time. I was wondering if it wcould be a dry shock absorber??
please please please help with any information you have - I really want to love this car but every time I think its sorted she turns around and craps on me!
Glen
Lets play guess the noise!!!!
Re: Lets play guess the noise!!!!
top mounts perhaps?
My friend had the exact same sound and area as yourself,it drove him insane.Although his was noticable at low speeds.Cant remember for the life of me what it was i'll check with him and post up again.
Dont sell up because of a noise it'll be fixable mate.
princess_trojan
Top mounts - silly question but how could I check?
Cheers Bradley, that would be top notch if you could get back to me!
Cheers to you both for taking the time to reply - many thanks G
I'd think it could be rubbing something or it might just need oiling if you can take it out and have a look ?
princess_trojan
The problem is that there is nothing there that should need to be oiled. Have ordered spring compressors from flea-bay and strip the suspension (with the help of my pops) and start by checking the top mounts.
I think I am going crazy with the noise - I tell people about the noise, they come for a drive and it stops, I get in and drive home and it sings to me all the way home
Are you sure that this is not just the usual TCA rear voided bushes weakening and ripping and the "ooh ooh" noise is the two now sort of separated bits of rubber rubbing against each other.
Sounds to me like it could even be a hub or something?
My hub wore out in a weird way, to the bearing wasnt a complete tight fit. Makes a weird knocking, but not all the time
princess_trojan
Update time!
Started to strip the suspension, spring compressors were too big and couldnt get a hold so used two old G-clamps - not safe but the joys of working on your drive.
We packed the top mount with grease and noise has gone.......for about a week and now its back again
So it seems to be the tops that need replacing.
