wishbone suspension arm
jordan1230_8
Post by jordan1230_8 »
can anyone tell me how difficult it is to fit front nearside wishbone arm to 05 polo
George Agdgdgwngo
Re: wishbone suspension arm
Post by George Agdgdgwngo »
Not really that hard if you are only doing the wishbone and not the bushes, track rods or ball joints, only really a few bolts off and back on. What are you changing it for?
George Agdgdgwngo
jordan1230_8 wrote: its a driving school car and unfortunately a pupil of mine oversteered a corner and bumped the kerb not really an enormous impact but ever since the nearside front end has been creeking and groaning when braking especially at low speeds ive been told its probably a bent wishbone as apparently this is a common problem
Wouldn't surprise me, they are pretty poorly constructed to say how important they are. I would recommend getting new ball joints and track rods as well though, as they could have been damage with the impact. Here are the part numbers I used for mine, an 03 TDi Sport:
6Q0 423 811
NS Tie Rod End
16.98
6Q0 423 812
OS Tie Rod End
16.98
6Q0 407 365 M
NS Balljoint
20.74
6Q0 407 366 M
OS Balljoint
20.72
N 101 277 07
Balljoint Bolt Hex (3 per side)
0.55
N 908 088 01
Balljoint Nut (1 Per Side)
0.54
You need to make sure that that the track rod arm is not also bent, these are pretty expensive but obviously will need changing if it is bent. The bottom number is the price I paid for my parts, I did get them quite cheap but gives you a rough estimate. I am not sure how many miles your car will have done, but being a learner car I would have thought a fair few, and I am not sure if you know about the wishbone console bushes. these are known for going as they have voids in the rubber that allow a lot of movement and tear, I recommend you change them for the following part:
6LL 407 183
Ibiza Cupra Front Wishbone Bushes (x2)
6.20
G 294 421 A1
Lube for fitting Console Bush
6.99
These are not very expensive but make a massive difference to the feel of the car, and will also outlast the car, whereas some people have changed the normal bushes several times. If I were you I would change the track rods, ball joints and bushes on both sides, you won’t believe the difference!
Here is a guide on doing the bushes:
http://briskoda.net/technical-guides/fa ... de/101781/
You only need to look at the Console Bush part of the guide, not the one they guy cuts out of the wishbone itself.
I will also post this up in your topic for others to see.
Thanks and hope that helps!
matus
Post by matus »
Hi guys,
can I use the Cupra wishbone also on Polo 6N or is this only for higher models?
I'm thinking replacing old one for somethin new and good quality.
Please can you advise?
matus wrote:Hi guys,
If you really mean "Polo 6N" then the answer is no, if you are thinking about fitting Cupra wishbones (slightly shorter?) to "lesser" Polos or Ibizas, then maybe they will fit although one side will have a cut-out to accomodate the different gearbox. I think that a few people have found that the Cupra TCA is slightly shorter so will reduce negative camber after lowering - this is just "forum facts" not found from actual experience.
