[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Sachs Clutch Feel? - UK-POLOS.NET - THE VW Polo Forum
Loooking to change my Clutch pretty soon.. I know the sachs kit is recommended on here. Just wondering how it feels once its changed? i.e is it soft, hard? do you get that kickback when changing quickly at high revs or is it sluggish ?
Just got my sach clutch installed last week, must admit it feels really light in comparison to the original.
It feels good but mine has a funny bite so getting the gear changes spot on takes time to get used to.
I wouldnt say "yes deffo get one its miles better" but if your clutch does need changing then its certainly worth getting one, for £110 they are well priced too.
Not slipping, but the bite point is right at the very top, you barely need to depress the pedal to change gear.
It also judders when moving away, unless you give it plently of welly and feed the clutch in quickly. It also sometimes takes a few attempts to get it into first every now and then..
