Hi. received my passenger xenon yesterday. and the range level controller is fine its the socket it connect to the reflector unit that has broke. its a white plastic ball socket piece with a T20 hex screw. can this be bought from anywhere? part number etc? or does anyone have one for sale please.
kind regards
James.
Xenon Range Controller White Plastic Bracket
Polo*
Re: Xenon Range Controller White Plastic Bracket
edit. are standard lights and xenons interchangeable parts? http://www.uk-polos.net/view ... 09&start=0
The ball sockets are yes
You cannot buy the internal headlight parts seperately, so you will have to salvage it from a halogen headlamp
Polo*
Just to be sure. Do you know the motor level behind the high beam bulb, which is removable. The bit that attaches to the end of the ball on the motor. Is the same in the standard halogen headlamp. I don't remember even seeing a motor in the standard headlamp. Soz I'm not understanding. Cheers for you help again mate. You know everything lol
Yes its identical
Some standard headlamps dont have motors...depends on the trim level and options specified from factory.
Polo*
Wicked that's good then. Cheers again
Polo*
Hi. If I bought some brand new hella electric standard 6n2 headlights. Would I be able to transplant my xenon internals to the new headlamps with no modifications. Is it literally plug and play. As I have now split my Xenons completely down and was hoping to pretty much make brand new Xenons. What are the part number for the hella headlamps and where is best bet to get them from from new. Can't seem to get anywhere with google etc. Manythanks
On a side note if got the ballast and bracket re galvanised so it looks like new. Not rusty anymore lol
All you need is some new clear faces for the lights - dont go transferring the internals as they wont fit into the halogen housing. Its just the front clear plastic that you would change.
End of the day, its a bracket, it serves a purpose - what is the point lol! Its not like you inspect it on a daily basis lol
Polo*
i was hoping the black housing could be changed a couple of brackets that fit to the car had been broke and glued back on.
The black housing is completely different on xenons - totally different rear cover design
You can get repair kits for the brackets from VW
Polo*
oh really. cool. i will enquire on my next visit. cheers mate.
Galvanized my Bracket and Ballast Box Case. was really rusted.
Galvanized Ballast by Evostar*, on Flickr
