Boot light microswitch
dantheram
Post by dantheram »
I know this has been covered a thousand times on here but can i get a quick refresh on replacing said item?
I have the trim off and can see the lock mechanism behind the boot handle, where exactly is the light microswitch and do i have to take out the mechanism to replace it?
Thanks,
Dan
dantheram
Re: Boot light microswitch
Post by dantheram »
Also, a part number for the switch would be great, if anyone remebers it from fixing theirs.
alexperkins
Site Admin
Post by alexperkins »
6X0 947 569
You need to take the boot lock out to get to it - use an M8 spline bit to remove the two bolts
The old switch just pops out once you release its clips
dantheram
Post by dantheram »
Thanks, Alex.
dantheram
Post by dantheram »
replaced the microswitch and still no joy. going to admit defeat and leave the light alone now not worth the bother trying to find out whats wrong. :evil:
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
dantheram wrote:I know this has been covered a thousand times on here but can i get a quick refresh on replacing said item?
Thanks,
Dan
It's only the "black box"/locking mechanism that you can see in the buttom of the bootlid when you open it that you have to remove. No need to take off the trim. It it only takes a few minutes to change it.
It's number 19 on this picture you have to remove. and in that part it is number 20 that is the microswitch.
http://www.wagenstad.com/index.php?modi ... e=8-827-20
dantheram
Post by dantheram »
Thanks for the info, i have done the job now but its not the microswitch which is at fault because i still have no boot light. :evil:
Mart!n-GTI-DK
dantheram wrote:Thanks for the info, i have done the job now but its not the microswitch which is at fault because i still have no boot light. :evil:
What about the light on the dash when the boot is open... Does that work?
And have you checked the wires and connections to the bulb? Or the bulb it self ;)
dantheram
Post by dantheram »
Replaced the bulb when i first got the car - no joy.
The dash 'boot open' light works perfectly.
Microswitch - replaced.
Need a multimeter to see if any power is reaching the terminals, if not god knows how the cables have been damaged.
Mart!n-GTI-DK
dantheram wrote:Replaced the bulb when i first got the car - no joy.
A common fault is that the break in the rubber tube from the bootlid in to the car... That's where I would check first.
dantheram
Post by dantheram »
Checked with a multimeter and the light has no earth so all i have to do is cut the wire an stick it to something metal and it should work.
dantheram
Post by dantheram »
s**t p*** b*******s!!
Cut the brown and red wire and attached it to some exposed metal nearby and the light works fine BUT it never goes off :oops: .
Can someone give me some adivce here because i know little about electrics, i thought the switch in the boot lock would have turned off the power and thus the light but it seems to just stay on :cry:
Mart!n-GTI-DK
dantheram wrote:**** p*** *********!!
You said it was missing an groundconnection...
I think that the microswitch may infact cut off the ground when the boot is closed... So as I wrote before... check the rubber tube between the car and the boot lid. :)
I just checked on my own... There is always 12V to the light even when the boot is closed. So the microswitch does cut off the ground connection.
dantheram
Post by dantheram »
I checked the tubing and the wire looks fine in there.
So the microswitch in the latch cuts the ground, what a bastard, if it cut the power i'd be home an dry now.
Can't think of any other solution other than rewiring the earth, which is not going to happen so . . . . . . i give up again :(
Mart!n-GTI-DK
have you checked the groundwires from the switch?
If you remove the cover on the inside of the lid? one of them must be broken... Unless it's the wire in the C-pillar. It shouldn't be a big problem to check...
