Boot light microswitch
I know this has been covered a thousand times on here but can i get a quick refresh on replacing said item?
I have the trim off and can see the lock mechanism behind the boot handle, where exactly is the light microswitch and do i have to take out the mechanism to replace it?
Thanks,
Dan
Thanks,
Dan
Re: Boot light microswitch
Also, a part number for the switch would be great, if anyone remebers it from fixing theirs.
6X0 947 569
You need to take the boot lock out to get to it - use an M8 spline bit to remove the two bolts
The old switch just pops out once you release its clips
Thanks, Alex.
replaced the microswitch and still no joy. going to admit defeat and leave the light alone now not worth the bother trying to find out whats wrong.
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
It's only the "black box"/locking mechanism that you can see in the buttom of the bootlid when you open it that you have to remove. No need to take off the trim. It it only takes a few minutes to change it.dantheram wrote:I know this has been covered a thousand times on here but can i get a quick refresh on replacing said item?
Thanks,
Dan
It's number 19 on this picture you have to remove. and in that part it is number 20 that is the microswitch.
http://www.wagenstad.com/index.php?modi ... e=8-827-20
Thanks for the info, i have done the job now but its not the microswitch which is at fault because i still have no boot light.
- Mart!n-GTI-DK
- Platinum Member
+dantheram wrote:Thanks for the info, i have done the job now but its not the microswitch which is at fault because i still have no boot light.
What about the light on the dash when the boot is open... Does that work?
And have you checked the wires and connections to the bulb? Or the bulb it self
Replaced the bulb when i first got the car - no joy.
The dash 'boot open' light works perfectly.
Microswitch - replaced.
Need a multimeter to see if any power is reaching the terminals, if not god knows how the cables have been damaged.
- Mart!n-GTI-DK
- Platinum Member
A common fault is that the break in the rubber tube from the bootlid in to the car... That's where I would check first.dantheram wrote:Replaced the bulb when i first got the car - no joy.
Checked with a multimeter and the light has no earth so all i have to do is cut the wire an stick it to something metal and it should work.
s**t p*** b*******s!!
Cut the brown and red wire and attached it to some exposed metal nearby and the light works fine BUT it never goes off
Can someone give me some adivce here because i know little about electrics, i thought the switch in the boot lock would have turned off the power and thus the light but it seems to just stay on
- Mart!n-GTI-DK
- Platinum Member
You said it was missing an groundconnection...dantheram wrote:**** p*** *********!!
Cut the brown and red wire and attached it to some exposed metal nearby and the light works fine BUT it never goes off.
I think that the microswitch may infact cut off the ground when the boot is closed... So as I wrote before... check the rubber tube between the car and the boot lid.
I just checked on my own... There is always 12V to the light even when the boot is closed. So the microswitch does cut off the ground connection.
I checked the tubing and the wire looks fine in there.
So the microswitch in the latch cuts the ground, what a bastard, if it cut the power i'd be home an dry now.
Can't think of any other solution other than rewiring the earth, which is not going to happen so . . . . . . i give up again
- Mart!n-GTI-DK
- Platinum Member
have you checked the groundwires from the switch?
If you remove the cover on the inside of the lid? one of them must be broken... Unless it's the wire in the C-pillar. It shouldn't be a big problem to check...
