Hi all,
Fitting a new clutch cable after mine snapped. its on on the pedal mount, but there is not enough slack to mount the end piece onto the actrual clutch lever on the gb?
Is there a technique to doing this?
clutch cable fitting
Brute force and ignorance IIRC. It helps if someone can push on the gb connection point whilst you heave on the cable and manhandle it into place between you.
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: clutch cable fitting
hmmm see where you are coming from- but there is at least 2 inches to go
Are you sure you have the correct cable? I did mine recently and didn't find it too hard, certainly wasn't 2 inches short. also Is it adjusted to its longest lenght?
- joe2612
Thats what a thought, its this one here : http://www.eurocarparts.com/search/6464 ... /Car-Parts
- joe2612
Yeah wrong cable, remembered why i dont go to Euros' !
