clutch cable fitting
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Post by joe2612 »
Hi all,
Fitting a new clutch cable after mine snapped. its on on the pedal mount, but there is not enough slack to mount the end piece onto the actrual clutch lever on the gb?
Is there a technique to doing this?
Keeno21
Post by Keeno21 »
Brute force and ignorance IIRC. It helps if someone can push on the gb connection point whilst you heave on the cable and manhandle it into place between you.
joe2612
Re: clutch cable fitting
Post by joe2612 »
hmmm see where you are coming from- but there is at least 2 inches to go :|
neilw
Post by neilw »
Are you sure you have the correct cable? I did mine recently and didn't find it too hard, certainly wasn't 2 inches short. also Is it adjusted to its longest lenght?
joe2612
Post by joe2612 »
Thats what a thought, its this one here : http://www.eurocarparts.com/search/6464 ... /Car-Parts
joe2612
Post by joe2612 »
Yeah wrong cable, remembered why i dont go to Euros' !
