RCD 510 & 9wZ Bluetooth
Today I received a 9wz bluetooth kit from the spanish guy "BlueWagon", having stripped out the RCD 510 and interior light assy I patched in the module with the supplied leads, but for the life of me could not get any phone or laptop to detect bluetooth in the car.
The phone kit was recognised in the RCD 510, but all the options in telephone set up were "greyed out", save for the factory reset.
VCDS reported no faults, recognised the module straight away, so no faults there.
Any ideas? Or has any one fitted this module (5N0 035 730 D) to a 6R with RCD 510 and had no problems?
VMT
Bowcaps
VMT
Bowcaps
Re: RCD 510 & 9wZ Bluetooth
Am not 100% Sure mate, but am sure theres an option in VCDS to enable the bluetooth module. Just have a check if youve got VCDS.
yes you have to enable the bluetooth module to the car you can do by vcds ( vagcom ) thats how got mine to workNMavs wrote:Am not 100% Sure mate, but am sure theres an option in VCDS to enable the bluetooth module. Just have a check if youve got VCDS.
Thougt so
hope it works for you bud. If you dont mind me askin, where did you get your bluetooth module from and how much did it set you back? I really want one, as ive just fitted the rcd510 in mine.
I contacted the vedor "BlueWagen" in Spain, he informed me the 9wZ only works on highline (GTI Polo 6R) as the module has to detect the phone not the phone detect the module.
He is despatching a 9w7 module which is compatible with the Polo 6R's
HTH
Bowcaps
p.s. I checked VCDS, I cold find no specific "Bluetooth" option, but the Telephone module was enabled
HTH
Bowcaps
I have now installed the 9w7 unit, although the bluetooth module had to be installed at the back of the drivers chair as it would not fit at the front of the drivers chair.
It works really well, it's just a shame it's not an option in the UK, I can't think why VW would notr allow it to the UK market?
Bowcaps
Bowcaps
so how muchos ?
and how did you get in contact with the guy ?
The kit (complete with harness & VW discreet mic) was £175
If you do a search on Ebay for "Bluewagen", he is based in Barcelona
HTH
Bowcaps
HTH
Bowcaps
Bugger that. Al buy the adaptor bits for £20 and fit my Becker with Bluetooth built in lol
Will this work with the RNS 310?
Norbreck21a
I fitted the bluetooth box in the passenger footwell. Behind the A pillar trim (where the little cubby hole is for a reflective jacket), there is a double skin to the outer and inner body shell assembly, with a hole just the right size to fit the bluetooth box in. I covered the box in foam to stop rattles and pushedit in (quite a snug fit).
Did this on the wifes car the day she got it 3 months ago, and it's been working perfectly ever since. Made the install much easier as I didn't have to remove the sill trims or seat.
I may look at a relocation then, thanks for the information.
Bowcaps
Bowcaps
My Polo GTI arrives next week, and I think I may have made a mistake in asking the dealer to fit the VW Touch Bluetooth kit
I am planning to get an RNS 510 satnav. What do you think my options are? Are the mic cables likely to be compatible with the 9W7 box?
There are two mic holders between the internal lights, the RDS 510 has similar voice control as the RCD510 quite easy to fit as the 9wz / 9w7 comes with a genuine VW mic
HTH
HTH
OK, I got an RNS 510 and bluetooth fitted by HazzyDayz and it's great.
One small problem; the bluetooth 'hijacks' the Midline MFD display and will only show either phone information or navigation arrows if the satnav is active. I can't get to the normal MFD displays.
Any ideas?
Any ideas?
