FAO 1.0ltr and 1.3ltr engine owners!(single point injection)
Karl_CLCoupe
- Platinum Member
From what I can gather its everything including the modified bolts. Regarding the power increase, I think it came to the conclusion it was more sound than power.
Was this thread started for a group by? I seem to remember it being a batch of induction kits.
Anyway, like I said gimme a month or two, and I'm a taker.
Karl.
Karl.
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
Nice noise, plus I wouldn't have to arse about getting a new filter every 5000 miles or so and going through the whole painful (literally) affair of getting the Spi airbox off. Just pop the cone off instead and give it a wash.
I'll settle for instructions and bolts, if doug fancies becoming a tool shopper!
EDIT......
Hmmm and theres the matter of this mysterious "orange sensor" - wassat do again? - and what to do with the hot air feed as well!
I think, induction kit in summer, original setup (with a grille "scoop"?) in winter? Only a half hour switcharoo
Gaz GT, that pic you posted wayback of the standard intake extended to the grille with some kind of rectangular ducting sitting behind the grille, what did you use for that? Looks like bits off an old hoover!
Mebbe you can combine the two..... some grille ducting directing/scooping air towards the replacement cone filter on the end of the kit?
After all F1 cars can see a 20hp improvement at 120mph with that sort of thing (...it sez 'ere), so we might get a mighty 1hp extra at full pace. Every little helps!
(as for the carb/inlet manifold bore being small... well... is it much bigger on the GT/G40? the size of the hole just determines the surface area of air that can fit thru - if it's going faster or is mildly compressed... say, by coming in thru a bigger, less restrictive pipe and then being squeezed down, you'll still see a performance gain. faster airflow = better carburation/mixing of injected fuel, too, so low end torque might get a boost. think about the exhaust system - there's parts that are far wider bore than the outlet valves after all, but people still think to make them a bit larger! the stuff coming out of those valves can be pressured at several Bar)
EDIT......
Tahrey, this is what I have done to mine, and it works really well. You can't see from the picture, but the cold air feed goes from the induction kit, down to the bottom of the grille. I have used a drain pipe overflow typr thingy as an airscoop, that is mounted on the little air vent below the fog light recess. I got the black pipe from GSF for £2.40 for about 1.5 metres.
the bolts themsleves i have to make using a lathe! but i also need the air intake bit to modify them to take the new bolts!Tahrey1043 wrote:OK, so which bits do we have to source ourselves, and which bits are we signing up to Doug for?
this is all done if u don't want to take ur studs out!
at the min, i am trying to get the sleaves out of a couple of the golf intakes but am having some problems getting them out! must of been luck when i did it the first time! but we have some ideas how to get em out otherwise!
everything else, u can buy urself! i just thought it would be easier if i did the complete kit! but if u want to get the bits urselves, thats fine!
Tahrey1043
LogIK - sweet
So you get a large volume of moderately cool air from the engine bay, and a good forced-cold feed as well. Out of interest, where's that pipe from the hot air feed go to?
(and what was your engine size again?
Doug.... what do you have to do to the air housing to make it accept the bolts? Is it just drilling out the bolt holes slightly to a larger diameter, or is there something more complicated (like making a hole with a thread in it)?
Just as a random thought, would this work for carbed variants? Mk2s and already-modified Mk3s?
Tahrey, glad you like the setup. Works really well and hardly cost me anything. The induction kit was £14 off eBay, the Jetta airbox was £5, pipes were £2.40 and the other stuff used is unused drainpipes and drainpipe reducers. Works a treat, honestly.
As for the hot air pipe, it actually goes no where. The reasons why I put the pipe on are 1. I had spare pipe to use up 2. It directs any hot air coming from the hot air outlet on the manifold away from the induction kit, which can effect performance.
My engine is the 1043cc AAU SPI. My next mod will be ignition advance and vacuum advance to try and squeeze every last ounce of power out of my 45bhp machine
the holes in the air housing have to be made bigger to accept the larger bolts, this sounds easy but the holes on the housing have a metal shaft in them, these have to be taking out but when u try and drill them out, they just spin! on mine, we managed to skim the top of the metal sleaves off with a mill, but we're having problems with the current ones as they aren't easy to hold onto the table of the millTahrey1043 wrote:Doug.... what do you have to do to the air housing to make it accept the bolts? Is it just drilling out the bolt holes slightly to a larger diameter, or is there something more complicated (like making a hole with a thread in it)?
as for fitment to a mk2, i really don't no, as far as i no they are quite similar, but i may have to have a look into that, i'll try and fit it to my old mk2 and let ya guys no
hope this helps
regards
doug
Tahrey1043
Tahrey...
Won't have much more power than standard. I can't take the cat off, coz its an L plate
I reckon, with the mods that I have done now, plus the ignition and vacuum advance, plus the AAU chip, I reckon it would be closer to 50BHP. You aint gona get more out of a 1043cc engine, coz the capacity of the engine is the limiting factor.
The ignition advance is really simple to do. You need to set you timing to standard using a timing light (which I am wating for off Dom.) Once you have done this, you simply loosen the dizzy and rotate it by a few degrees in the direction it is spinning - ie advance it. What this does is advances the spark which gives the flame a slightly longer time to burn, which in turn means slighly more power. The advance is usually set by ear, but I'm sure on the MK3, the optimum advance is 7 degrees.
Modern engines don't need this timing advance, because they actually have a negative spark on the exhaust stroke so that any unburnt fuel is burnt off on the final stroke of the engine.
Older cars such as ours, with mechanical distributors, only spark on each of the four points of the distributor cap which is timed for the third stroke of every cylinder.
Tahrey1043
Yes, you're right in what you say, but the person who told me this said it also improves the power of the engine as there is another small ignition and so timing advance is not needed. However, they could be wrong and therefore I could be wrong
Anyway, as for setting the advance, the best way to do it is to do it by ear, then take the car out for a spin. The optimum advance is just BEFORE you have advanced it too far and "pinking" occurs. This happens because the spark comes way too much before TDC and the fuel/air ignites when the piston is still travelling upwards. If you advance it just before pinking occurs when the engine is under load, you are at the optimum point since it is the maximum you can advance it by.
Not sure exactly why it is best done this way. Maybe it varies slighty between each car
. Not sure at all.
Tahrey1043
P'raps it means the Alfa Twin-Spark idea has become more popular? So it's another ignition while it's about 1/2 way thru the down stroke... a little more push and less waste of fuel.LogIK wrote:there is another small ignition and so timing advance is not needed.
(man, the savings and performance we could get if only all the manufacturers worked together and we got a single engine out at the end with ALL the different enhancements in one place
Oh yes that old chestnut...........Anyway, as for setting the advance, the best way to do it is to do it by ear, then take the car out for a spin. The optimum advance is just BEFORE you have advanced it too far and "pinking" occurs.
(duhhhhhh til you said about the pinking, i was going... what's this about setting it by ear?! hehe..)
Yep it probably has a lot to do with how worn the engine is, carbon build up on the valves etc, as well as various other conditions.. You're making very small and precise alterations to the timing after all (or should be!). The grade of fuel is another factor - which is why you have to run the GT and G40 on a *minimum* of our 95 octane "premium unleaded" (which is better than the "regular" stuff in certain euro countries) to prevent it, and they run nicer on 98 octane. The higher the octane rating, the slower (slightly) the petrol is to combust or even pre-combust without a spark if the engine's too hot. Therefore it's best to use it in higher performance engines that are likely to have more advanced timings and higher running temperatures, and has no benefit (or even a performance harming effect) in more basic units such as a factory-spec 1.0 or 1.3 Spi... which are more suited to the quicker and more volatile nature of the 95-RON (or even the 91-RON stuff which is *their* minimum).If you advance it just before pinking occurs when the engine is under load, you are at the optimum point since it is the maximum you can advance it by. Not sure exactly why it is best done this way. Maybe it varies slighty between each car. Not sure at all.
I hope I got all that stuff right
Thinking of that - another effect of you doing this may well be to shift your peak power and torque RPMs higher at the same time as increasing the output... as the pistons can move faster before getting out of the zone where there's the best "push" from the explosion, as the shock-wave covers a larger area (ie starting when the piston is higher up the bore, and ending at the same point)... so you'll have to be changing gear higher, getting it rechipped for a higher rev limiter and a better electronic ignition and fuelling map, so on and so forth wahey..
OK thats it, i gotta open a window, the CO2 is getting to me
