![Sad :(](./images/smilies/icon_sad.gif)
02s can handle the same power as 02j or it is better?
Can't say for sure but I would assume the same power as an 02j as they are very similarAgwnistikotatos wrote:As I see 02m is the only way...
How TFSIs can handle 500+ horsepower?9N3 Turbo wrote:Can't say for sure but I would assume the same power as an 02j as they are very similarAgwnistikotatos wrote:As I see 02m is the only way...
These gearboxes don't come in the TFSI only the FSI which is non turbo and only around 150 bhp and the 1.9 diesel which I believe are 105 bhpAgwnistikotatos wrote:How TFSIs can handle 500+ horsepower?9N3 Turbo wrote:Can't say for sure but I would assume the same power as an 02j as they are very similarAgwnistikotatos wrote:As I see 02m is the only way...
I think, only the bellhouse is different for the 240mm clutch... Gears and axles are the same...9N3 Turbo wrote: These gearboxes don't come in the TFSI only the FSI which is non turbo and only around 150 bhp and the 1.9 diesel which I believe are 105 bhp
This is what I say...9N3 Turbo wrote:I would disagree as these gearboxes bolt directly to a TFSI if you change to the smaller flywheel. I know someone in the process of doing this
The wavetrac LSD, just came out from the oem GVZ gearbox and the crown replaced with the crown fromAgwnistikotatos wrote:This is what I say...9N3 Turbo wrote:I would disagree as these gearboxes bolt directly to a TFSI if you change to the smaller flywheel. I know someone in the process of doing this
That they are the same except the clutch housing.
pm'dPadi wrote:alright mate... i saw youve upgraded your front discs and calipers... just wondered do you have the old ones still and what sort of condition they in as im looking for an upgrade as the 17s make mine look tiny!
Get as much bits out of the way for ease.Agwnistikotatos wrote:The wavetrac LSD, just came out from the oem GVZ gearbox and the crown replaced with the crown fromAgwnistikotatos wrote:This is what I say...9N3 Turbo wrote:I would disagree as these gearboxes bolt directly to a TFSI if you change to the smaller flywheel. I know someone in the process of doing this
JYJ.
Tomorrow I'm going to close the gearbox and put it on car. Any tips for installation?
