Right chaps, I have had wheelman waynes' old polo gti, 6n2 for a while now, and am slowly but surely working my way through various problems on her.. The abs light coming on when you hit 30mph exactly being one.. Firstly it was throwing a front offside sensor code, replaced it, then permanent light from ignition click for which I have fixed the dry solder joint in the control module. Then replaced (after much swearing) the 2 rear abs sensors. The light still comes on at 30 mph.. So am going to do the front near side sensor too just incase it's that, will be replacing discs and re-bleeding whole system, as I doubt it's ever been done(spongy underperforming brakes).
My question is, when I was replacing the rear sensors I noticed that the abs spiders that slide over the inside of the rear hub were incredibly corroded.. Spent a couple of hours cleaning them as best I could, but still not happy with the way they looked. Does anyone know of anywhere that I can get those pick up rings from? Anyone done them before?
Secondly, anyone had similar probs on their abs system, if it all fails, I think I'm going to remove it all, as I can drive, and don't really like abs anyhow, was just trying to keep originality.. Anyone done that on here??
Need help on this folks..
sooner it's done, the sooner I can refurb the bbs in black, and get her dropped
