Hi there
Iv just signed up, I bought a white 6n2 last week!
I'm just wondering if cruise control is a possible retrofit? Iv just read a detailed guide on how to do it on a lupo tdi, which doesn't have it as an option. I guess one of the biggest obstacles is whether the 6n2 is fly by wire throttle, or cable
Thanks in advance
Jamie
6N2 cruise control?
6N2 cruise control?
The auk engine which is in the 1.0 I think is fly by wire. Interesting fact there
think I've seen this done though
Re: 6N2 cruise control?
Does that mean they all are bud?
Iv seem it done on a derv 6n2, just hoping the petrol is the same!
It's very possible.
It's easy too.
It's easy too.
How easy tho? Iv heard 6n2s are cabled throttles, not fly by wire which I presume is a problem? How easy is it then? I know you need to make your own loom, and get it activated with vagcom, just wanted to make sure a 1.4 16v 76bhp could support it. I know i also have to get the ecu pinouts
Before I type it out, go look under your bonnet and see what you've got.
Accelerator cable or potentiometer.
6N2 cruise control?
Mine is definitely fly by wire man.
http://forums.clublupo.co.uk/index.php?showtopic=44327
Same principle applies, I know the GTI has the capabilities, not sure on the 1.4 16V thing though.
I'll check when i get home. Thanks.
Yeah that's the guide i read and got me thinking, just hope it's possible. Is there anyway to check its possible on the ecu before I start?
All 6n2s are drive by wire apart from a few early models using older hybrid 6n engines
Cruise control is only properly possible on the 1.4TDI, 16V options and the GTI, though I can't be 100% on the 16Vs
Mine isn't! W reg, 1.4 16v cable
Aye its mainly the 1.4 16V engines that still had cable throttle due to a surplus of left over parts from the 6n 16vs
