Any1 know if you can take the speedo apart?
Hi does anyone know if you can get to the speedo at all as mine keeps getting stuck at 4000 revs even when car is off it stays there
thanks
Yeah. If you take off the hood above with some screws then the speedo screws out.
just undo screws it's fair simple!
Re: Any1 know if you can take the speedo apart?
Me and my Dad looked earlier today and cant find any area where you can unscrew it hmmm..
I think the screws for the hood are on the underside. I can't look cause my cars in the garage. I've ha mine off to play with the speedo though and it wasn't hard I remember that much
Under shiny edging shroud on gauge cluster cover.. remove this part (clipped in so be gentle) then you will be able to see all the screws.. 3 or 4 from memory..
remove the shroud, then there are a few holding the clocks themselves in.. Remove those, and the cluster pulls straight up.. carefully unclip loom, and presto.
Oh screws are torx heads btw.
I once took my clocks apart to try and put some tape over the ABS light as i couldnt work out the problem, the light shined through the tape when i had finished so was a complete waste of time
Fixed the ABS in the end though
