As the post says, knocking noise from the o/s front wheel just started yesterday, almost like a calper is loose or something, can feel it through the pedal. I've had a good poke about and can't find anything loose or broken. Plus when the car's up on the jack there's no knocking
Very frustrating, I'm thinking perhaps a CV joint, there's no play in the bearing and the caliper/pads are all secure, the knocking seems to be worse when going round a left hand bend, and seems to get really bad when 'coasting' in gear, eg the power is off, I'm kinda stumped so she's off the VW on wednesday to see if they can locate the problem. No doubt it'll be something REALLY expensive lol
What I was wondering is have any of you guys had a similar issue?
cheers,
Jim
