vw polo gti fuel
mozzapologti
vw polo gti fuel
got mine mapped today and said i would get better gains from vpower just wonderd what every one was running cos they said they hadnt had car in that wasnt running v power lol
Re: vw polo gti fuel
Mine is run exclusively on vpower, mines mapped to make the most of it however if i need to use lower grade fuel I can retard the timing on my map to keep things safe.
V-power or tesco 99Ron Momentum at a push. Not worth using 95ron on a mapped Polo GTI IMO.
Does anyone here regularly run their GTI on 95 RON rather than the higher octane stuff?
The price gap between the fuels seems to be getting bigger, and I'm fed up of paying the higher price. My car isn't mapped or anything.
WatchcamGTI
BPs stuff is only 97 ron i notice. Have used v power ... Not noticed any difference to 95 to be honest. Would fill with high octane if could find it each time. But is it really necessary? Not a money issue from my perspective but convenience .... I cant always queue for the petrol station one high octane pump!
If your remapped high octane quality fuel should be the only one you fill with.
High octane gives you more bang per buck and is known to reduce the risk of pre detonation.
vw polo gti fuel
Mine only gets sainsburys 97ron I've run it on 95 a few times can't say I've noticed a difference but it was only small amounts for a short period
I only use BP Ultimate or Shell V Power.
Supermarket super unleaded is crap and I won't use it. The reason they sell it so cheap is because the RON/Octane is right at the bottom limit of what is acceptable to call super unleaded, and the mainstream petrol stations won't sell it. Therefore I won't buy it
I used to use V Power in my 1.2 TSI but I get the same returns from BP Ultimate and it's slightly cheaper
If the Shell garage was local though i'd probably carry on using that
Vissa
V-power = RON97
Ultimate = RON98
Here in the Netherlands Ultimate is the cleanest and highest octane you can get, our German neighbours got RON100, lucky bastards!
Ultimate = RON98
WatchcamGTI
Vissa wrote:V-power = RON97
Ultimate = RON98
Ultimate is 97 here in the UK.
mozzapologti
yeah im in the forces and based in the forces shell fuel over there is so much better qualitty then here
