Which upper strut brace for 6n2?
jackson
Post by jackson »
Hey all
Been looking for a strut brace that doesnt need the header tank to be relocated. From pictures ive seen the OMP brace should be ok but thought i'd task you guys before i push the button.
cheers 8)
6N2 GTI 00
Re: Which upper strut brace for 6n2?
Post by 6N2 GTI 00 »
The OMP Upper brace will fit but it does need the coolant tank repositioning, it's not necessary to totally relocate it but if I remember correctly you can swing it out of the way by moving the bracket and then cable tie it in place once the brace is fitted. Alternatively you can fabricate a bracket and relocate the coolant tank after the brace is fitted.
jackson
Post by jackson »
Sorry for the double post! Well if it needs relocating its not a problem im just lazy :) I work at an engineering firm anyway. Cheers dude
