Been looking for a strut brace that doesnt need the header tank to be relocated. From pictures ive seen the OMP brace should be ok but thought i'd task you guys before i push the button.
The OMP Upper brace will fit but it does need the coolant tank repositioning, it's not necessary to totally relocate it but if I remember correctly you can swing it out of the way by moving the bracket and then cable tie it in place once the brace is fitted. Alternatively you can fabricate a bracket and relocate the coolant tank after the brace is fitted.
