9n3 oem shock absorbers
I'm after some oem shock absorbers as mine are leaking. I think all 9n models have the same shock absorbers. Thanks.
Re: 9n3 oem shock absorbers
I have full front and rear suspension available from a 1.4tdi 2005 model they had done 50k when I removed them and are still as new.
How much would you want for the shock absorbers? As I already have lowering springs ready to go on. Could you send me the vag part numbers off them so I can double check with mine. Thanks, Danny.
Sorry I havent got back to you they're the standard ones for the polo all are the same even the gti ones it is only the springs that are different I will have a look over the week end at the sticker on them and will let you know.Oobadooba wrote:How much would you want for the shock absorbers? As I already have lowering springs ready to go on. Could you send me the vag part numbers off them so I can double check with mine. Thanks, Danny.
Gti shocks are different to lesser models. Not just the springs.
??? not true my friend the only difference is the springs 15mm lower ride height ref the stealers ie VW.rover220 wrote:Gti shocks are different to lesser models. Not just the springs.
the monroe fitment is 16451for the front no matter what polo it is from 2002 to 2010 and the rear is 23950 again no matter what polo from 2002 -2010 ie 9n and 9n3.
I have fitted many over the years the springs are the difference. You can buy heavy duty shockers which will give a firmer ride and again there is no difference for whatever model of polo be it a 9n 1.2s or a 9n3 gti all the same. Are you on the right site with your tag of rover 220?? lol
They are different, I have some in the garage from my gti and some from a 2006 1.4. Shocks have different part numbersRITCHAT wrote:??? not true my friend the only difference is the springs 15mm lower ride height ref the stealers ie VW.rover220 wrote:Gti shocks are different to lesser models. Not just the springs.
