Best BOV/Dump Valve for 9n3?
jak-rabbit
Hey guys,
Anyone have any recommendations for a BOV for my 9n3? I have heard the 1.8t VAG engines aren't too happy with atmospheric and thus need to use recirculating? are there any recirculating valves that would give me a little "PPSSSSHHH" (sounds childish...i have just always wanted one)
cheers
cheers
Re: Best BOV/Dump Valve for 9n3?
Just a forge 007p or 008 re-circvalve and a cone filter should do the trick for that I believe, I sure someone else will pop up and give you a definitive answer.
Andy
Andy
jak-rabbit
sounds good to me! Thanks for the reply
It sounds childish i know but deep down we have all wanted to hear the dump noise
jak-rabbit
Sounds good to me. I came across this video and want the same dump noise this one is running (same engine so i don't see why not) https://www.youtube*.com/watch?v=YDKBesb-Wg0
^^ what he said
If you also remove the sound deadening from the bonnet it lets more sound through
Same as above plus it is louder if you ake the rubber bonnet seal off too
I have got the Forge Splitter SPLIT-R Dump Valve fitted to mine. Gives a little psssh sound and recirculates some air so get best of both worlds. You also have the choice to make it fully recirculation and fully atmospheric. Costs about £140 ,but like you I love the psssh sound so was totally worth it.
candypolo12
I have a baileys dump valve I don't know what make of baileys it is but it gives a good chatter on lower boost and then a loud pssshh when your giving it a little more:)
- lukey GTI
I use 007p and open cone filter plus take the heat sheild off the underside of the bonnet. You hear more noise lol well childish
Sent using tapatalk
Sent using tapatalk
Mr Blobby
I've got one too and like he has said it's the best if both worlds and makes a good sound. It's easily adjustable and no need to change any springs when you mod your engine.J-Dan wrote:I have got the Forge Splitter SPLIT-R Dump Valve fitted to mine. Gives a little psssh sound and recirculates some air so get best of both worlds. You also have the choice to make it fully recirculation and fully atmospheric. Costs about £140 ,but like you I love the psssh sound so was totally worth it.
Should they be making a chattery noise but mines has started doing this but heard its not a good thing ?candypolo12 wrote:I have a baileys dump valve I don't know what make of baileys it is but it gives a good chatter on lower boost and then a loud pssshh when your giving it a little more:)
Mr Blobby
It shouldn't make this noise I don't think. As far as I am aware chatter is the air flowing the wrong way and hitting the fins on the turbine of the turbo and this can damage the turbo
I'd get it checked out if it making this noise.
Yeash this is what i thought
Done exactly the same to mine and it makes the noise you are looking for quite nicelylukey GTI wrote:I use 007p and open cone filter plus take the heat sheild off the underside of the bonnet. You hear more noise lol well childish
