Removing Intake Manifold 9n3
Who knows how to do it
Looking at removing to get sprayed same colour as my colour coded engine cover
Best regards
Best regards
Re: Removing Intake Manifold 9n3
looked at mine other day when i was fitting my boost gauge...
f**k that s**t
too much stuff to come off
if you do take it off, get a newsouth performance gasket to go back on though
f**k that s**t
![Laughing :lol:](./images/smilies/icon_lol.gif)
andyc315 wrote:looked at mine other day when i was fitting my boost gauge...
**** that ****too much stuff to come off
Wont do it unless someone has a tutorial lol
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
its not hard, just remove the plastic pipes connected/or in the way
then remove alan key bolts, should be around 14'ish im not sure but some are well awkward to get to
also remove the little goldish? pipe near it and egr valve has to come off
greypolo9n3 wrote:its not hard, just remove the plastic pipes connected/or in the way
you done it before man? im not confident on doing it at all
- greypolo9n3
Yeah ive done alot of intake and exhaust manifolds on TDI's its the same principle on the petrolsTony Boi 92 wrote:greypolo9n3 wrote:its not hard, just remove the plastic pipes connected/or in the way
know of any tutorials bro?greypolo9n3 wrote:Yeah ive done alot of intake and exhaust manifolds on TDI's its the same principle on the petrolsTony Boi 92 wrote:greypolo9n3 wrote:its not hard, just remove the plastic pipes connected/or in the way
its pretty self explanatory, take all the pipes off going to it and remove all the bolts holding it to the head.
- greypolo9n3
yeah as above...as you go along undoing bolts..you'll see what needs coming on and off
thats how i taught myself...first car i did was a new'ish golf tdi 170! lol
you just need to be careful you dont slip any of your alan keys in the bolts as they are quite soft and they can shear off which leaves then un-screwable.
But first remove the EGR valve and anything which comes in the way, then make your way to loosening the bolts off the manifold
doing my 1.4tdi on and off takes 25 mins!
any particular order to anything?greypolo9n3 wrote:yeah as above...as you go along undoing bolts..you'll see what needs coming on and off
Re: Re: Removing Intake Manifold 9n3
Take off your backbox first, then your parcel shelf. This balances the weight out so it's easier to removeTony Boi 92 wrote:any particular order to anything?greypolo9n3 wrote:yeah as above...as you go along undoing bolts..you'll see what needs coming on and off
Sent from my GT-I9100P using Tapatalk 2
You bell ...andyc315 wrote:Take off your backbox first, then your parcel shelf. This balances the weight out so it's easier to removeTony Boi 92 wrote:any particular order to anything?greypolo9n3 wrote:yeah as above...as you go along undoing bolts..you'll see what needs coming on and off
- greypolo9n3
Lol thats funny
"replaces backbox after realising it was a joke"
