Lowering polo 6r
aaronon
Re: Lowering polo 6r
Post by aaronon »
It's not actually smaller than 57.1 ...It's bigger. I'm just a crap photographer! :P :D
Are the rings important? Is it ok if my ring is one cm bigger than it should be?
Lol all this talk of wide rings ... You'd know its Friday night! :O
Joe9n3
Post by Joe9n3 »
i fitted xxr 527's to my car, looked the business!!!!
spec:
17"
8.25J
Offset 25
Wrapped in 215/40/17
Lowered on 25/40 H&R springs
didnt rub THAT much only on wollowing bumps and hard bumps!
+it was only catching a little bit on the tyre
i was going to fit 195's but just got rid in the end (wish i hadnt but may buy some more!)
SO im gonna say your gonna be fine with that spec wheel & tyre
everyone + you needs to stop stressing so much about such a modest spec wheel & tyre :roll:
Especially when there are other people out there on coilovers with a more aggressive stance!
aaronon
Post by aaronon »
Yeah but you didn't 'rub that much' yet mine will be 5mm even lower at the front. Saying that I'm only 7.5 wide.
Just stressing out because i've never changed alloys lol :oops: :oops:
Joe9n3
Post by Joe9n3 »
what do you not get?
Mine..
8.25J
ET25
Lowered 25/40
215/40/17
and yours..
7.5J
ET35 - 40
Lowered 30 all round
215/40/17
Il leave you to make your own decision... :roll:
aaronon
Post by aaronon »
Hey... We'll I think all those numbers mean that your tyre would stick out more and be more prone to rubbing? That's good news for me :) I was just thinking about when turning the front wheel incase the tyre didn't clear the arch lol. Was just nervous that's all :( Sorry buddy if I annoyed you!
aaronon
Post by aaronon »
I can't wait anymore!!!
I ordered the springs today :D :D
aaronon
Post by aaronon »
So I'm getting these fitted tomorrow and wanted to put my new wheels on tonight in preparation for VW.
Could I get my alloys off? Hell no! What a joke. All bolts out. Booted them as hard as I could. Kicked them. Did everything and they didn't budge. I could drive around forever with absolutely no bolts in the wheels keeping them on.
What am I meant to do if I get a puncture and pull over to the side of the road :as
So will explain to VW tomorrow and hopefully they put my new ones one instead of the current ones :)
chrispy.
Lowering polo 6r
Post by chrispy. »
I had this with my car, me and my dad took 20 mins whacking the wheel with a block of wood with a huge hammer.
Its basically the seal they put around wheel. Once its off, we put some copper grease on there, now when i want them off, they drop off just be staring at them
Roundsquare
Post by Roundsquare »
I thought it was the heat that generated between wheel and hub that bonded them together.
I had the same problem and only managed to get the wheel off by using a 4x4 length of wood and hitting the tyre from behind.
I was told to just undo the nuts slightly and then drive a few yards and this would free them but they weren't for budging.
I've since removed all the wheels on the family cars and put some copper grease round them. As like you say if you are stranded and have a puncture.
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
It's all about leverage...
I have experienced this many times. And with experience comes wisdom. :D
If you take a block of wood and hold it up against the inside of the wheel and reach under the car with a "normal" size hammer and wack the s**t out of it, chances are thai it will take a long time per wheel,
BUT if you instead switch out the hammer with a big 3 foot sledgehammer and just "gently" tap the wheel (still with the block of wood in between of course) it wil most times come of the first time.
So the saying isn't all wrong : If all else fails... Get a bigger hammer.
aaronon
Post by aaronon »
Haha how do you hold the wood in place while you swing a big hammer? Doesn't the wood vibrate and ruin your hand lol
JayW
Post by JayW »
I seen this before as well, when I had a puncture. Took it to a tyre place and the guy basically bashed the wheel at the top with the palm of his hand a few times as hard as he could and it come off. Took some beating but he got it off in the end lol. Wheel wasn't hurt but can't say the same for his hand..
Mart!n-GTI-DK
aaronon wrote:Haha how do you hold the wood in place while you swing a big hammer? Doesn't the wood vibrate and ruin your hand lol
Get at piece big enough so that it can stand against the wheel on it's own...
aaronon
Post by aaronon »
Oh! Good call.
Pick up the car at 4:30 and will ask what the Craic is and how you're meant to change for a puncture considering I can't exactly carry a sledgehammer and wood in the boot (especially in Belfast where I'd get done for terror crimes lol)
alexperkins
Site Admin
Post by alexperkins »
As above, a bit of copper grease on the center hub generally stops the wheel sticking. Thats generally where it holds as opposed to on the bolt mounts
