[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Mart!n's BlueGT thread - Now with: LED Indicators - Page 3 - UK-POLOS.NET - THE VW Polo Forum
I picked up a new BlueGT about two weeks ago and loving it so far.
Unfortunately my car doesn't have the xenon and LED running lights option so I have purchased some new builds but having read the posts on here fitting them does not seem to be case of plug and play
As I understand it, to fit Xenons retrospectively and legally is an awful lot of work. You need automatic leveling and washers etc.
I regret not speccing mine up with them included. Going for super white bulbs might be the best back up option.
hornmeister wrote:As I understand it, to fit Xenons retrospectively and legally is an awful lot of work. You need automatic leveling and washers etc.
Cheers for your reply, When I said I had purchased new bulbs I was referring to just that and not fitting a retrospective xenon kit. However just getting access to fit the bulbs looks a challenge in itself?
Arran wrote:Cheers for your reply, When I said I had purchased new bulbs I was referring to just that and not fitting a retrospective xenon kit. However just getting access to fit the bulbs looks a challenge in itself?
On the new Polo's you remove the headlight to change the bulbs. Which is actually very easy.
A little guide here:
- Remove the plug on the back og the headlight.
- Remove the two screws (2) (NOT the one market 1)
- Pull the headlight straight out
Cheers will give it a go tomorrow.
I did read a post where someone recommend putting masking tape along the top of the bumper before removing them to stop scratching?
