Rear Brake Discs/Pads and Shocks
mswuk
- Drives: VW Polo Gti 6n2
I need to order some parts for mot time and I need rear shocks and rear discs and pads.
Looked and found some on gsf but just need someone to confirm they will all fit.
REAR BRAKE PAD SET
PART NO : 646VG0010
REAR BRAKE PAD SET
VOLKSWAGEN POLO MK3 1.6 16V GTI Petrol (10/99 - 09/01)
Important Note There is more than one rear brake pad option for this vehicle, if unsure which type you require, please contact us
MORE INFO
Specification
Quality vetech
Height [mm] 52.9
Length [mm] 87
Manufacturer Restriction TRW
Thickness [mm] 15
OR
REAR BRAKE PAD SET
PART NO : 646VG0082
REAR BRAKE PAD SET
Fitting Position Rear Axle
MORE INFO
Specification
Quality vetech
Height [mm] 52.9
Length [mm] 87
Thickness [mm] 17
AND DISC'S
REAR SOLID BRAKE DISC - 232MM DIAMETER
PART NO : 603VG0254
From construction year 06/2000
Braking / Drive Dynamics For vehicles with ABS
Special Order Info Please order 2 for a pair
MORE INFO
Specification
Quality vetech
Brake Disc Thickness [mm] 9
Diameter [mm] 232
Height [mm] 39
Hole Arrangement / Number 5/4
Minimum Thickness [mm] 7
Pitch Circle Dia [mm] 100
Thread Size 14
AND FINALLY SUSPENSION
REAR SHOCK ABSORBER PAIR
PART NO : 513VG0193
MORE INFO
Specification
Quality trwpair
Shock Absorber Mounting Type Bottom eye
Shock Absorber Type Gas Pressure
Shock Absorber Mounting Type 2 Top pin
I am on a tight budget so hopefully these or some of these will do.
Any help is greatly appreciated.
REAR BRAKE PAD SET
PART NO : 646VG0010
REAR BRAKE PAD SET
MORE INFO
Specification
Quality vetech
Height [mm] 52.9
Length [mm] 87
Thickness [mm] 15
OR
REAR BRAKE PAD SET
PART NO : 646VG0082
REAR BRAKE PAD SET
MORE INFO
Specification
Quality vetech
Height [mm] 52.9
Length [mm] 87
Thickness [mm] 17
AND DISC'S
PART NO : 603VG0254
MORE INFO
Specification
Quality vetech
Diameter [mm] 232
Height [mm] 39
Thread Size 14
PART NO : 513VG0193
MORE INFO
Specification
Quality trwpair
Re: Rear Brake Discs/Pads and Shocks
Vetech discs and pads are shocking for quality. All they do is squeal generally
Have you got a TPS near you?
All of the above are available in the vw economy range for not much more and you have peace of mind in it being a genuine approve vw part
mswuk
cheap for a reason then!
think I'll give them a miss and give vw a call.
what is this eco range?
They told me before the make an eco alternator for roughly 180 squid but no longer make the original.
TPS (the trade parts specialists ie vws trade outlet) now produce a range called economy parts which are simply vw quality parts at have been slightly modified to better suit the needs of cars over five years old
Cost savings have been made in minor changes to materials, reduced packaging and general modifications, but the performance is in no way effected
1J0698451P rear brake pads / JZW698451A economy rear pads
6N0615601A rear discs
6N0513031T rear shocks
Sadly the suspension GTI parts aren't on the economy range - the correct part numbers are above however so you can use them to with go genuine via TPS or with GSF, but try go for the premium range and wangle trade discount.
mswuk
gone onto mister auto and they sell monroe shocks £30.05 each with that part number you gave me! So £60 odd is not too bad I think.What do you reckon? Also are these straight forward to fit? I have fitted suspension before so is there any specialist tools I need?
Seems reasonable
The rears are easier then the fronts. You should probably get your hands on a set of spring compressors though if you are running stock suspension it's generally easy enough to do the rears without
Other than that, you've just gotta move the exhaust out the way to get to the lower bolt
Make sure also you note the order and orientation of the top mount bolts as you remove them
mswuk
sweet I got spring compressors so its all good! the also sell bosch brake discs and pads are these any good?
Yeah they would do the job fine
mswuk
cool.
Also do you happen to know the part numbers i'd need for alternator/tensioner/belt so I check their prices as vw want £180 for a new eco alternator so wanted to compare prices?
Apparently the alternator is 90amp but i'd prefer 120amp as of stereo and other electical stuff going in the car but if not 90 will do!
JZW903021EX TPS list as £107.89+ VAT
90A will be ample. Only the tdi models need 120s and even then it's overrated
Belts and tensioner - you meaning aux belt or cam belt and tensioner?
036198119E is the cam belt kit.
mswuk
not cam belt but the alternator belt (is there only 2 belts on the car?).
cannot find a bosch alternator with corresponding part numbers that match yours.
3 belts on the GTI - alternator, cambelt and secondary cambelt
038903018A or 038903018R are the parts for the GTI
http://www.mister-auto.co.uk/en/alterna ... 1!920.html
That's the bosch alternator youll need
036145933Q is the belt
http://www.mister-auto.co.uk/en/drive-b ... K1125.html
That's the belt youll need
Use SAVE15 promo code and you'll save 15% on it all too
They will load a 100 quid deposit on for the alternator, as you have to return the old one to them in exchange
mswuk
whats the deal with it saying "without rev counter contact"? whats all that about?
