IZVVC
Posts: 142 Joined: Sat May 10, 2014 6:45 pm
Post
by IZVVC » Fri May 23, 2014 7:32 pm
Hi guys I recently bought a footrest of eBay:
http://www.ebay.co.uk/itm/151283055793
However I'm completely lost in how to install it
Does anyone know how, or has anyone installed one before, any help would be greatly appreciated
Posts: 8834 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Fri May 23, 2014 8:39 pm
ciclo on Wed Jun 11, 2014 8:31 pm, edited 1 time in total.
IZVVC
Post
by IZVVC » Fri May 23, 2014 10:56 pm
Thanks ciclo, but do you have a guide which tells me how to install, or can you tell me how to install, like which parts of the screws go where?
would be really grateful
Post
by ciclo » Sat May 24, 2014 6:10 am
alexperkins
Site Admin
Posts: 14873 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Sat May 24, 2014 10:57 am
Line up the plate, piece holes with a brad awl. You should be able to put a domed washer on each bolt and screw it in with some pressure without the need to use a nut on the back
IZVVC
Post
by IZVVC » Sat May 24, 2014 1:07 pm
Thanks guys I'll try and get it done and update it in my thread
zebraman
Posts: 71 Joined: Sun Apr 27, 2014 4:42 pm
Post
by zebraman » Sat May 24, 2014 1:16 pm
Make sure there is nothing behind before you start drilling holes in the footwell.
Pipes are often fixed to the firewall in the engine bay.
alexperkins
Site Admin
Post
by alexperkins » Sat May 24, 2014 1:17 pm
This goes onto the plastic footrest - its empty behind there. Its not going through the footwell metal wall!
zebraman
Post
by zebraman » Sat May 24, 2014 4:42 pm
Fair enough then. Drill away.....
IZVVC
Post
by IZVVC » Sat May 24, 2014 5:41 pm
can't manage to unscrew the footrest?
alexperkins
Site Admin
Post
by alexperkins » Sat May 24, 2014 11:17 pm
You don't need to....just do what I said
IZVVC
Post
by IZVVC » Sat May 24, 2014 11:31 pm
alexperkins wrote: You don't need to....just do what I said
did you mean pierce?
alexperkins
Site Admin
Post
by alexperkins » Sat May 24, 2014 11:34 pm
Indeed. Bradawl is the tool used. Thinking about it, I could've been clearer lol
IZVVC
Post
by IZVVC » Sat May 24, 2014 11:35 pm
alexperkins wrote: Indeed. Bradawl is the tool used. Thinking about it, I could've been clearer lol
i don't think a bradawl will pierce it, the footwell plastic is very touch, rant bradawls normally used for wood
alexperkins
Site Admin
Post
by alexperkins » Sun May 25, 2014 9:48 am
It did on my 6N2. They may have changed the plastic. In that case mark it and drill a small hole just through the surface a little smaller than the bolt. That'll do the job
