Footrest Help
Footrest Help
Hi guys I recently bought a footrest of eBay:
http://www.ebay.co.uk/itm/151283055793
However I'm completely lost in how to install it
Does anyone know how, or has anyone installed one before, any help would be greatly appreciated
Re: Footrest Help
Re: Footrest Help
Thanks ciclo, but do you have a guide which tells me how to install, or can you tell me how to install, like which parts of the screws go where?
would be really grateful
Re: Footrest Help
Re: Footrest Help
Line up the plate, piece holes with a brad awl. You should be able to put a domed washer on each bolt and screw it in with some pressure without the need to use a nut on the back
Footrest Help
Thanks guys I'll try and get it done and update it in my thread
Re: Footrest Help
Make sure there is nothing behind before you start drilling holes in the footwell.
Pipes are often fixed to the firewall in the engine bay.
Re: Footrest Help
This goes onto the plastic footrest - its empty behind there. Its not going through the footwell metal wall!
Re: Footrest Help
Fair enough then. Drill away.....
Re: Footrest Help
can't manage to unscrew the footrest?
Re: Footrest Help
You don't need to....just do what I said
Re: Footrest Help
did you mean pierce?alexperkins wrote:You don't need to....just do what I said
Re: Footrest Help
Indeed. Bradawl is the tool used. Thinking about it, I could've been clearer lol
Re: Footrest Help
i don't think a bradawl will pierce it, the footwell plastic is very touch, rant bradawls normally used for woodalexperkins wrote:Indeed. Bradawl is the tool used. Thinking about it, I could've been clearer lol
Re: Footrest Help
It did on my 6N2. They may have changed the plastic. In that case mark it and drill a small hole just through the surface a little smaller than the bolt. That'll do the job
