Furthermore, you can come on holiday to Spain, will be greeted with open arms.
But in the UK there are many good things that we do not have in Spain.
How to install automatic lights on a Volkswagen Polo 6R with halogen headlights w/o st/stp system (OEM)
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
I just want to remember that I decided not to provide technical support for this installation because there are many factors to consider.
My time is very limited, I have no time for everyone.
Again, I apologize for this.
jobbercete
- Drives: Polo 6R 1.2 TSI 90cv Sport
Good guide Ciclo, but I can't install it OEM....my BCM it's a 087K one
Regards!
Regards!
You can. Precisely this guide is ideal for you. http://www.uk-polos.net/view ... 85#p463243
-To do this you have to buy a new 089, 090.
-You already have the light sensor.
-You also need a set of 9 cables for adaptation, and the full kit for automatic lights.
jobbercete
Yeah, Ok...but I think that buying a new BCM it's a bit expensive (over 100€, right?) plus all the wiring...etc
. Also, I'm not very good with cables, I'm a Plug&Play guy
. I'm saving money for a RNS unit, then...we'll see
A new BCM (for example):
Link removed. It is not right.
jobbercete
That's a good one Ciclo..... the better the BCM, the more money we can "invest" on the car
No thanks, I think I'm going to stay with my basic BCM and mods plans, really appreciate the help and the ideas from this post
This installation guide for automatic lights working with original parts in Polo 6R with halogen headlights is mainly to share with all those French, Germans, Italians, Belgians, Dutch, South Africans, New Zealanders, Mexicans, English people, etc... who contacted me via email asking a solution to have the automatic lights OEM with their factory light sensor.
There are many owners of polo 6R that have made many impressive modifications and many of them already having the right BCMs for this installation.
Of course, as usual, this installation guide is available to everyone. Will be updated permanently.
Remember that me don't have a polo 6R with halogen headlights, neither with start stop system.
Soon, a good French friend, probably will be the first in the world to have the automatic lights "OEM" in his polo 6R with halogen headlights without start stop system.
---> http://www.uk-polos.net/view ... 00#p484613
Dear Ciclo,
I am from the Dutch Mypolo forum. Some of the guys have refered me to you. As it seems you have quite a lot of experiance in the field of fitting in OEM components in the 6r.
I have receintly bought myself a pair of OEM GTI Xenon Headlights for my Polo 6R Bluemotion from 2010. For the correct fitting I bought a pair of adapterharnesses from another forummember (A 14 pin to 10 pin, with an integrated diode, for High beam signaling at position 0).
However once I had installed the headlights I experienced some difficulties.
At position 0 of my headlight switch, the DRL Leds are on.
At positoin 1 (citylight) LEDs are on, but I get a headlight mallfunction light on my dashboard
At position 2 (low beams), with car switch to contact but motor off the xenon and leds are on, with headlight mallfunction light
At position 2 (low beams), with my motor on, the xenon is on for 5 seconds, then blinks few times and then it turns off! Even if I switch the light switch to 0 and back, the wont turn on again.
I have tested the headlights of somebody else, and the same problem occurs. We have also switched the adapterharness, with no result.
So I guess the problem must be in VCDS settings.
My car has a 88 B boardcomputer.
I have tried to turn off all mall function headlight options (vcds / 09 elect / byte 16) but still get the mall function light turn on.
I changed byte 18 from (61 to 41) but with no result.
Below you can find my VCDS scan:
Some info about the components;
Headlight (right): 6R941 040 D (productie datum 30/06/2014) / Valeo
Balast / Controller: 8KO.941.597 E / MH7 W003T22071 / H03/S0004 14530 (productie datum 30/05/2014) / Mitsubishi Electric
Controller: 6R0 937 088 B
Hopefully you can help me with finding the right settings for my BCM. PS the dutch forum threath where i am discussing this problem: http://forum.mypolo.nl/polo-v-6r/10548- ... ter-7.html
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61
VIN: WVWZZZ6RZBY110880
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 906 021 B
Component: R3 1.2 DCM3.7 H04 7345
Revision: 12004001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TDI03103P906021B 001023
ROD: EV_ECM12TDI03103P906021B_VW25.rod
VCID: 2757E3DC5E13D526F59-8072
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416E00B2842D24EA82D100521300
VCID: 86090E5835D96C2E2EF-80D3
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 356B39949CBFB7B6775-8060
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 B HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0321
Revision: BU046001 Serial number: 0328 261100849
Coding: 24B02BBF08A10000002001B03C2B0CD0CF80610F7E860041200000000000
Shop #: WSC 124697 483 00190
VCID: 3D7B21B4A48F6FF6BF5-8068
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Coding: 48BC30
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 3
Reset counter: 80
Mileage: 49836 km
Time Indication: 0
Date: 2043.14.00
Time: 12:53:56
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 7
Reset counter: 80
Mileage: 49836 km
Time Indication: 0
Date: 2043.14.00
Time: 12:48:19
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 3
Reset counter: 80
Mileage: 49836 km
Time Indication: 0
Date: 2043.14.00
Time: 12:53:58
Fault Priority: 3
Fault Frequency: 18
Reset counter: 80
Mileage: 49836 km
Time Indication: 0
Date: 2043.14.00
Time: 12:48:19
Component: VW10Airbag00K H09 0020
Revision: -------- Serial number: 003GX007S94E
Coding: 00304B
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A917A68ED41C84E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3572SRB40000CB64CA0D
Crash sensor for side airbag; passenger side:
Serial number: 3582SRB40000CB652263
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405B6THNCAPIO
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB40636VQ8AIHB5
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H04 0304
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 387530A083AD4ADE6C3-806D
Address 19: CAN Gateway Labels: 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 110910F1001336
Coding: 7D021D00080000000002
VCID: 32610288ADD1A08E527-8067
Component: IMMO H04 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F670BFCEAE38D663D9-807A
Address 56: Radio Labels: None
VCID: 55AB9914BCFF97B6975
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 030B1A5A
VCID: F4ED449057456EBE00B-80A1
Component: J367-BDM H07 0125
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 42
Mileage: 0 km
Time Indication: 0
Date: 2042.14.10
Time: 13:11:30
End ---------------------------------------------------------------------
Hi Crave89,
With this specific new coding for your Polo 6R all lights should work fine with your xenon headlights retrofitted.
New coding: 24B02BBF08A10000002001B03E2B0CD0FF80672F7E861041200000000000
Easy, copy from here and paste in the indicated arrow.
Do it.
Byte 0: 24 or 3C depends on the forum where we look.
If you continue to have problems, they are not of coding.
***Tell us the results***
Do it.
crosspolo2014
Thats Ciclo!!!
crosspolo2014
Dubbel post
crosspolo2014
ciclo wrote:Hi Crave89,
Do it.
Hello Ciclo,
I have the same setup on my crosspolo 6r everythin works fine exept my leds.
I have a issue whit my led drl on my oem xenon headlight.
When i turn my steering wheel the leds are blinking.
Sorry about my english!
Is there maybe in vcds a setup adaption of voltage for the leds?
I think the voltage is too much swinging as soon as I turn the steering (electronic).
What do u prefer to do?
Many many thanks!!!
Ciclo I have to tell, you are a genieus! Thank you very very much. With these settings, I get no mallfunctions anymore and the xenon headlights are working as they should.!! This saves me a lot of worrying.ciclo wrote:Hi Crave89,
Do it.
However, what I do get now is that the DRL light bulp which is in my bumper below (next to my fog light) is turned on during citylight and low beam light..
I have turned it of during position 0, by changing byte 23. However, the DRL light turns up in the other light settings.
Next to that it isn't pretty next to the white xenon and white leds, I believe it isn't allowed here in the Netherlands.
I have tried getting it of, by removing the TRL pin at the back of the light switch, but with no result.
Could you say this is a VCDS setting aswell? And is it possible to turn it of at all settings? Maybe by removing a fuse?
98octaneblood
- Drives: Blue GT MY15
Really impressed about your skills and your upgrades
I expect my Blue GT arrives home next week. By the way, did you painted the black outer plastics from the bumpers? They look satin.
Cheers from Spain
Cheers from Spain
