This may be a daft question!!!
Just playing with the Polo 9N because previous owner has bodged sooo much!!
The passenger lock just fell out every time you unlocked the door, investigated and found that drivers and passengers locks had been switched because one was broken!!!! new parts fitted, switched back to correct side bingo!!
Now the daft question....should it be central locking with the key. There is an electrical connection to each lock module.... but no central locking
if IT IS cl and it is not working...where do I start looking for the reason it does not work??
What else would the electrical connection be for if not CL
CRAIG
