I've seen that there's a new style of metal pedals for the 6C, they have larger black areas than those available on the 6R, does anyone know if they would fit on a 6R?
Thanks!
Do the new style of sports pedals fit the 6R?
Re: Do the new style of sports pedals fit the 6R?
If I remember correctly, the clutch and brake will fit but the throttle is a bit different. You could check out ciclo's Polo build thread since he did a retrofit.
Failure
http://www.uk-polos.net/view ... 30#p480972
Solution
http://www.uk-polos.net/view ... 25#p484325
Proof
http://www.uk-polos.net/view ... 72#p485572
I can assure that in this way assembly is perfect, and I think that is the only way to assemble 6C new style pedal caps (the only ones that it sell) on 6R without breaking anything.
Solution
Proof
iichel, beatty and ciclo, thanks so much for your replies!
