Do the new style of sports pedals fit the 6R?
MattS
Drives: 6R Red Match 1.4
Post by MattS »
I've seen that there's a new style of metal pedals for the 6C, they have larger black areas than those available on the 6R, does anyone know if they would fit on a 6R?
Thanks!
Re: Do the new style of sports pedals fit the 6R?
If I remember correctly, the clutch and brake will fit but the throttle is a bit different. You could check out ciclo's Polo build thread since he did a retrofit.
beatty599
Post by beatty599 »
Failure
http://www.uk-polos.net/view ... 30#p480972
Solution
http://www.uk-polos.net/view ... 25#p484325
Proof
http://www.uk-polos.net/view ... 72#p485572
I can assure that in this way assembly is perfect, and I think that is the only way to assemble 6C new style pedal caps (the only ones that it sell) on 6R without breaking anything. :)
MattS
Post by MattS »
iichel, beatty and ciclo, thanks so much for your replies! :D
