New Lights & Lowering
chrispy.
Re: New Lights & Lowering
Post by chrispy. »
Your a star! :)
Just blame it on me if your neighbours ask :)
CrypticG
Drives: 1.2 TSI SEL (6C)
Post by CrypticG »
+1 on the pictures, these look smart! how come they are so cheap? very interested in some for my 6c sel
lxm
Post by lxm »
Hi Robert
Same as the other guys, more pictures please in daylight and night time head on.
I always see these replicas advertised but never come across any pictures of them working online or on any forums... so this is a first :mrgreen:
chrispy.
Post by chrispy. »
How do the LED DRLs work on them?
robertsm66
Drives: VW 1.2 TSI
Post by robertsm66 »
The LED's are good, not as bright as the genuine ones but good all the same. You do have to connect a single wire to the postive on the battery which I think is related. There's no other wiring required or adjustment required.
robertsm66
Drives: VW 1.2 TSI
So another crazy saturday night for me taking pictures of my car in the dark.
So bare in mind the cars on a kerb, the rears been lowered and not the front, plus the front left is on a stand due to shock refit issue.....so the light patten is a bit funky.
DRL / Side lights Only
Dipped Beam
High Beam
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
chrispy. wrote:How do the LED DRLs work on them?
They are not DRL's. They are only sidelights.
robertsm66
Drives: VW 1.2 TSI
They're actually permanently on, so you could call them DRL's. Although my Polo uses the low beam as DRL's which I need to sort out.
Mart!n-GTI-DK
robertsm66 wrote:They're actually permanently on
So are the sidelights. ;)
robertsm66
Drives: VW 1.2 TSI
I'm starting a new thread named 'Day time running lights or side lights ?' or maybe just Fog lights !
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Post by greypolo9n3 »
Just worried that the light pattern is for LHD cars since you bought these from germany?
Im confused because i have a gti BCM on my tdi...so maybe replica headlights wont work? and i might need oem genuine headlights lol confuuuusedddddddd
robertsm66
Drives: VW 1.2 TSI
The lights can be manually adjusted to adapted the pattern for LHD and RHD. Once I've sorted my front shocks I'll have a play and feedback.
If you have standard 6r Halogen lights then these are a straight swap.
lxm
Post by lxm »
robertsm66 wrote:They're actually permanently on, so you could call them DRL's. Although my Polo uses the low beam as DRL's which I need to sort out.
From a previous thread, testing on my polo and with help from ciclo I found the below, it should work for you.
Pull out the light switch in the cabin, and at the back of it ;
1) Bend or insulate pin '3' = Disables low beam DRL function at switch position '0'
2) Bend or insulate pin '6' = Disables plate lights at switch position '0'
3) VAGCOM 'turn off parking/side lights at position 15' = Disables front & back parking/side lights at position '0'
Obviously you could try a combination of the above to get your lights working they way you want. I personally with your headlights would do step 1) so that your LEDs would be on all the time and act like true Volkswagen bi xenons, only thing is your rear reds would be on too.
robertsm66
Drives: VW 1.2 TSI
Good news on the light adjustment front. The direction of the HID lens is easily adjustable so they can be adapted for LHD and RHD. You can obviously adjust the height of the beams, however you can't do this when the light is installed but the self levellling does work as it should, so adjustment should be minor.
I still haven't driven with them at night, so couldn't tell you how good they are.....they do look great though !
kaz101
Drives: blueGT
Post by kaz101 »
May I ask how exactly you adjusted the lights from LHD to RHD? I've email the ebay shop about the adjustment on the lights, they insist is only LHD! :roll:
I'm interested on these lights too, as I pick up My BlueGT today! Wanted the Xenon Lights options, but we needed the car asap so we taken one from the stock list which we waited 3 weeks as it was already on its way to uk.
