robertsm66 wrote:They're actually permanently on, so you could call them DRL's. Although my Polo uses the low beam as DRL's which I need to sort out.
From a previous thread, testing on my polo and with help from ciclo I found the below, it should work for you.
Pull out the light switch in the cabin, and at the back of it ;
1) Bend or insulate pin '3' = Disables low beam DRL function at switch position '0'
2) Bend or insulate pin '6' = Disables plate lights at switch position '0'
3) VAGCOM 'turn off parking/side lights at position 15' = Disables front & back parking/side lights at position '0'
Obviously you could try a combination of the above to get your lights working they way you want. I personally with your headlights would do step 1) so that your LEDs would be on all the time and act like true Volkswagen bi xenons, only thing is your rear reds would be on too.
