Non Canbus power supply for rear parking sensors
keithcheetham
Drives: 60 plate 1.2-60 SE 6R with winter pack
Post by keithcheetham »
I have fitted aftermarket rear parking sensors to my daughters 60 plate 1.2 SE, but the Canbus is obviously not giving the correct voltage for the control unit as I have tapped into the reversing light. Is there an alternate 12V power supply, such as possible standard wiring in place for rear power socket that I can use for the sensors control unit, switching through a relay off the reversing lights.
Re: Non Canbus power supply for rear parking sensors
Yes, there is. If you have a 12V socket, that's easy.
Else I'd suggest the dome light.
A relay controlled by the reverse light should work, thats how my camera works :)
keithcheetham
As there is no power socket fitted in the rear of the car, could someone advise where they are located when fitted so that I can look if the wiring is fitted as standard. I would then be able to tap into it if available.
rsmagee
Drives: BlueGT (6C)
Post by rsmagee »
I would use a tap-a-fuse, and run the wire under the sills. Its super easy to slip a wire under.
