Your opinion on Under bonnet Insulation
sendoc
Drives: polo match 1.4 (6R) & Toyota Avensis T3
Post by sendoc »
What do you people think of under bonnet insulation? What's the purpose?
My 2011 6R doesn't have one.
My old 9N polo had one and the noise level was still high.
Do you think it's worth buying one and installling it?
alexperkins
Site Admin
Re: Your opinion on Under bonnet Insulation
Post by alexperkins »
It dampens down engine noise and insulates the engine more
chrispy.
Post by chrispy. »
I wanted to get rid of mine but thought it must be there for a purpose.
Thanks Alex :)
sendoc
Post by sendoc »
Thanks for your replies.
i am planning to put some sound proofing layer and get a bonnet insulation and see what happens to the noise level.
I did not think twice about fitting the Ford under bonnet sound insulation to wife's 1.6SI with the Zetec engine, if it was the Ghia model it would have been fitted it at factory.
Sometimes, the manufacturers need to trim costs a bit and that might seem to be a bit penny pinching, but it is reality.
If you want to do this, go for it, challenge the norm!
TheFrog
Drives: 2015 Blue GT
Post by TheFrog »
For some reason, the Blue GT can sound a bit like a diesel when cold, so I removed the felt and put some Dynamat Xtreme behind it. Made a big difference.
http://www.dynamat.co.uk
TheFrog wrote:For some reason, the Blue GT can sound a bit like a diesel when cold, so I removed the felt and put some Dynamat Xtreme behind it. Made a big difference.
I think that all modern engines sound a bit like that when first started, even worse if you keep the car in a garage as the sound bounces around. Bring back nice big fat lazy engines that sound as smooth as sewing machines as soon as you start them, and guide you to a filling station every few miles - I know about this, I have an Audi S4, mind you it is noisier than my old 2.8 V6 4Motion B5 Passat - and slightly more economic on petrol. So there you go, "bag of spanners noises and good economy" or "smooth as a sewing machine and very greedy" - that seems to be the current choice - bring on improvements - oh no, that probably means silence then a lot of whining/humming???
audiobull
Drives: 6r
Post by audiobull »
From my test drive today I am certainly looking to buy some insulation for under the bonnet. Its a 1.2 3cylider and sounds like my 2.5 T5 engine..... a bucket of bolts.
I added insulation (vw genuine) onto the engine, under bonnet, engine cover and bottom engine cover of my T5 and it works great..... i can now hear them speaking on the speaker at mcdonalds so certainly worth it on noise reduction.
The 1.2 polo engine sounds rackety so would like to hear about what genuine insulation is available for the 6r.
sendoc
Post by sendoc »
Anybody happens to know the part number for the under bonnet insulation for 6R Please?
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
6R0863831B
And then you will need 10 of these clips:
1H5863849A01C
sendoc
Post by sendoc »
peter_dk25 wrote:6R0863831B
1H5863849A01C
Thanks Peter.
audiobull
Drives: 6r
Post by audiobull »
Thank you Peter
Is said to be £51.03 from dealers so need to ask for some discount.
There has been mention that the insulation comes with the clips already can you confirm this?
peter_dk25
Drives: Blue GT
No - I had to buy mine, but they are very cheap!
sendoc
Post by sendoc »
Finally installed sound proofing foam and then insulation carpet on top.Noise has reduced to a comfortable level now.
Planning to put some more sound proofing material in the boot and doors later.Thanks for all your inputs.
coopern
Drives: Polo 1.4 BUD 9N3 petrol manual
Post by coopern »
Am considering fitting under bonnet insulation to my polo 9N3, wondered what model 9N the OP had, he doesn't say. VW sell part 6Q0863835, there's also same part with C and A suffix but I don't know what the difference is.
N
