Hi all,
I'm thinking about buying the replica xenons with LED DRL's that are available for the 6R but I don't know if they fit the 6C electronically. Is the headlight plug same as the 6R and would it work straight away like it's a 6R?
Replica GT/GTI xenons on 6C
Re: Replica GT/GTI xenons on 6C
the dectane replicas are more or less a straight fit, however i'm not sure you'll have a light bulb error for the LED strip
aaygen
- Drives: 6C 1.2 TSI Lounge
Thanks! If I fit them and they throw a bulb out error, would I be able to fix it with VCDS?iichel wrote:the dectane replicas are more or less a straight fit, however i'm not sure you'll have a light bulb error for the LED strip
frank.mehta
How is the light throw from these dectanes? Can someone who's used them extensively tell us?
