Some time ago I bought this portable inverter, it works great for the laptop.Mart!n-GTI-DK wrote:I would love to have both sockets in mine.CNK wrote:I would like to retrofit a 12v socket in my trunk
- federicodrdpro
- Drives: White Polo 6R TDI
Thanks! Which 12v fuse do you use for it?ciclo wrote:In rear side (cup holder) I used the original 12V socket from front side.federicodrdpro wrote: Which is the part number of your Rear 12v SOCKET oem?1J0919341H
You're great.iichel wrote: img]http://i.imgur.com/PVxP9ej.jpg[/img]
(in short)According ElsaWin diagrams you can install the two 12V sockets (U1-Cigarette lighter, U5-12 V socket) in the same wiring installation and use a 15A fuse. SB42 (original fuse in your car).federicodrdpro wrote:ciclo wrote:federicodrdpro wrote: Which 12v fuse do you use for it?
- federicodrdpro
Today I installed the Steering wheel. It works but lighting buttons not work. Why? Which differences are there in new BCM? Coding?
Thanks for the information federicodrdpro, it is very valuable to me.
The problem is not coding or adaptation of the BCM, the problem is software.
I'm sure many enthusiasts that make mods to their Polo 6R will buy the BCM Max 7E0937090, however also many of them with BCM High from factory can buy BCM High 6R0937087T (2015 --->) to solve the issue of the backlight of buttons if they have no intention to make additional improvements.
https://www.uk-polos.net/viewtopic.php? ... 30#p498043
- federicodrdpro
Thanks for the precious answer! Can I install the 7E0937090 ( Z4Y ?) In my Polo 6R without xenon?
P.S. I bought the VW Golf 7 RVC camera because it have the composite video signal. Do you know if is possible to change the golf 7 emblem with the Polo emblem? (Golf 7 emblem have a different design).
https://www.youtube.com/watch?v=KgaXrCBFWXk
https://www.youtube.com/watch?v=YVe5L_mfaOU
http://www.imagebam.com/image/4276f8474994222
http://www.imagebam.com/image/ca0bdf474993416
http://www.imagebam.com/image/029c55474993420
http://www.imagebam.com/image/1a96f9474993428
http://www.imagebam.com/image/947863474993435
http://www.imagebam.com/image/1d0f4b474993441
Is possible disassemble it?
Thanks Federico
Thanks Federico
Last edited by federicodrdpro on Thu Mar 31, 2016 2:57 pm, edited 5 times in total.
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
The buttons lightning is swiching by LIN bus signal. The new type MFSW requres other signal. This is BCM firmware ability and couldn't be activited by coding. So there are two ways to solve the issue:federicodrdpro wrote:Today I installed the Steering wheel. It works but lighting buttons not work. Why? Which differences are there in new BCM? Coding?
1) update the firmware of your current BCM
2) install the BCM manufactured after 04.2015
Yes, but you need to make changes in wirings and coding.federicodrdpro wrote:Thanks for the precious answer! Can I install the 7E0937090 ( Z4Y ?) In my Polo 6R without xenon?
- Wirings BCM Max
- Wiring CAN_bus IC->BCM (BCMs 7E0)
Thanks Federico
- federicodrdpro
Thanks for the answer! You are too helpfull
I am very thinking about change the BCM with the 7E0 version. But I don't know if this is the best solution for me.
I love do the retrofits in my Polo
Before I decide to buy a 7E0 version of BCM
, I would know the wirings changes and which are the possible retrofit with 7E0 version of BCM in a VW Polo.
P.S. For the VW Golf 7 badge, I work on it next week and post the result here
Federico
Hi Firegrafik, thanks for the answer and for the MP. I am thinking to change BCM, but I don't know if this is the best solution for me.firegrafik wrote:The buttons lightning is swiching by LIN bus signal. The new type MFSW requres other signal. This is BCM firmware ability and couldn't be activited by coding. So there are two ways to solve the issue:federicodrdpro wrote:Today I installed the Steering wheel. It works but lighting buttons not work. Why? Which differences are there in new BCM? Coding?
Federico
firegrafik
There is report concerning 7E0937090 BCM intergration on Polo from Russian Polo ownerfedericodrdpro wrote:......
Before I decide to buy a 7E0 version of BCM, I would know the wirings changes and which are the possible retrofit with 7E0 version of BCM in a VW Polo.
https://www.drive.net/l/9344124/
You could also read mine reports
https://www.drive.net/l/7318540/
https://www.drive.net/l/8632361/
https://www.drive.net/l/9309752/
I guess that this information is derived from my creations. Not right for Polo 6R Europe, are missing some important details* and others are not necessary.firegrafik wrote:There is report concerning 7E0937090 BCM intergration on Polo from Russian Polo ownerfedericodrdpro wrote:......
However it seems me well to have a rough idea of what to do.
*details that must be corrected in the future if he install other equipment. So he will work twice.
- federicodrdpro
Thanks for the answer. Now I study it.
P.S. A question about the RVC tube. Do you used 5K6 827 861 tube like in your guide? Because it seems short
You have to study this link in depth and detail. viewtopic.php?f=62&t=67799#p505742federicodrdpro wrote:Thanks for the answer. Now I study it.![]()
I insist, not for sale. (this only is for sale when I have time to provide tech support, not at this time, sorry)
No. I bought 50 metersfedericodrdpro wrote: P.S. A question about the RVC tube. Do you used 5K6 827 861 tube like in your guide? Because it seems short
gti16
- Drives: VW Polo 6r 1.6 TDI
Hello
Anyone know if the radio 3Q0 035 874 Polo 6C is compatible with Polo 6r?
Thank you
Thank you
