[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Engine Raisers 6n2 GTi - UK-POLOS.NET - THE VW Polo Forum
Thanks for answering, raise the level of my engine from the ground. So the shafts sit straighter in the box, as the car has been lowered and I am just tearing through gearboxes!
I know it can be done, and I've heard longer bolts and hockey pucks work, but that sounds a little bit dangerous to me.
The shaft entering the box is a fixed angle - unless you are attempting to force the CV joint further than it can safely go that should make little difference
