firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
CNK wrote:
Hey Alexander,
if you want, I can order and send you used BCM from Poland :wink:
Or you can try to send directly, buy as you know, many sellers don't send abroad.
Hello, Simon!
Have you read my minds? I'm thinking to ask your help in this deal when I be ready.
Thank for you tenderness!
firegrafik wrote:
When Byte29 Bit5 is 1, with switching low beam or just flashing high beam, there is "yellow bulb" warning light on Instrument cluster appears, but there is no any fault in the 09 centr.electr and in the other control units. :shock:
Very interesting. With Bi-xenon headlights (my R-line) there are vcds faults in BCM regarding to the LED headlights modules if this Bit is activated. Logically.
As for warning light, perhaps you have active a Bit for PWM or diagnostic lamp in BCM that it's no correct for this setting.
Just remind to others that read this that firegrafik have installed in his Polo Sedan the 6C LED headlights modules. :)
Edit :lol: :
I just checked that 6C and T6 use the same modules for LED headlights... :mrgreen:
https://www.drive2.ru/l/10602233/
firegrafik
Edit :lol: :
I had just thought about it, and checked it, I hadn't had PWM or diagnostic bits marked in 11,16 and 19 bytes
MikeNL
Drives: 6R 1.6 TDI
Post by MikeNL »
What parst do I need for the folding mirrors? I already upgraded my bcm to 7h093707089F. I have a polo 6R GTI 2011 3 doors
favi
Drives: 6R
Post by favi »
MikeNL wrote:What parst do I need for the folding mirrors? I already upgraded my bcm to 7h093707089F. I have a polo 6R GTI 2011 3 doors
viewtopic.php?f=56&t=58703&start=330#p481352
:wink:
MikeNL
Drives: 6R 1.6 TDI
Post by MikeNL »
:wink:
If I try to search these numbers in google I don't get any result though :(
favi
Drives: 6R
Post by favi »
I'm waiting for the man who's trying to encode folding mirrors.
I have 6R0959801BC and 6R0959802BH :> i will try it ;D If you are looking for window motors is a need to look at Etka those that have code-Pr 6XE
keep an eye out at bm-parts or bm onderdelen BV, and maybe also for ebay. sometimes a complete set is sold (mirrors, door motors and the switch)
bump bump.
did anyone ever notice how funny the coding of the ALWr in the polo actually is?
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0192000001000000
byte 0: vehicle type.
Hex 01 = Polo.
byte 1 (here it gets funny)
bit 0: ?
bit 1: rls installed
bit 2: LHD (mine is set to 0)
bit 3: leveling info via sensors and not via can (mine is set to 0 again)
bit 4: multilink rear axle and FWD
bit 5: multilink rear axle and AWD (the fixed rear axle for Polo 6R should leave both bits at 0)
bit 7: start/stop installed
byte 4
bit 0: headlight regulation active
if I would do what I think is right, then byte 1 would look like 10001110 HEX 8E (LHD + bit 3 ON + solid rear axle)
but then I get an error that the front axle height sensor is not there. and it needs a new basic setting.
maybe the label for byte 1 bit 3 is for the front axle, and it receives some kind of balance via sensor in the body instead of a front axle sensor
but i don't get why it's set to 01 in byte 5/6 since the polo has a solid rear axle without any independent suspension at all.
but this code is rejected with a code 22 :mrgreen:
How many sensors have your 6R? ONE
(leveling info via sensors and not via can)
one sensor = via can
two or more sensors = possibility offered to select
Therefore Byte1 Bit3 = 0 Image... :lol:
Byte1 Bit4: When you sell your 6R can say it has multilink rear axle ... :lol: :lol:
firegrafik
I will add some extra food for thought :D
On Russian Polo Sedans with factory bixenon two types of AFS control unit
With simple ABS
6R0 907 357 C Z0D
coding
0D4B000001000000
With ESP
6R0 907 357 C Z0A
coding
0D4A000001000000
6R (without start/stop)
Coding: 0112000001000000
6R Sedan (2016)
Àäðåñ 55: Êîððåêòîð ôàð (J431) Label: 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Êîìïîíåíò: AFS-ECU 005 0050
Ðåâèçèÿ: -------- Ñåðèéíûé íîìåð: --------------
Êîäèðîâêà: 0D4B000001000000
T6 (two sensors) G77 Rear right vehicle level sender G289 Front right vehicle level sender
Component: AFS-ECU 005 0050
Coding: 0FCA020001000000
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
Is it possible to reset the position of the xenons? There's an option on Xenon range, but again, I need the access code...
96 428 ;)
Locked
